Thread Number: 21908
Kenmore Direct-Drive Outer Tub Leak Help: |
Post# 344598 , Reply# 2   4/24/2009 at 22:02 (5,451 days old) by cleanteamofny ((Monroe, New York)   |   | |
Post# 344603 , Reply# 4   4/24/2009 at 22:25 (5,451 days old) by dnastrau (Lords Valley, PA)   |   | |
...as it could be something like a nail floating around between the inner and outer tub. Andrew S. |
Post# 344973 , Reply# 6   4/26/2009 at 19:43 (5,449 days old) by yogitunes (New Jersey)   |   | |
te pump is simple to replace...just two clips top and bottom...pop off real easy with fingers or a screwdriver...disconnect the two hoses....keep a towel or pan nearby....and pull off motor shaft....new one will just slide onto motor shaft just align the slots in motor shaft with that of the pump...reconnect hoses and snap the clips back on...and your set as for the lid switch i would just clip the wires and twist together with tape....will spin when needed... |
