Thread Number: 21918
Transporting GE Filter Flo Washers |
Post# 344420 , Reply# 1   4/23/2009 at 21:02 (5,478 days old) by toploader1984 ()   |   | |
the fabric softener dispenser is available at repairclinic.com item number 281015, i just bought a 1980s ge filter flo to start my collection too! bought mine 2 months ago and absolutely LOVE it! |
Post# 344517 , Reply# 3   4/24/2009 at 10:57 (5,478 days old) by lotsosuds ()   |   | |
Can anyone give me info on transporting GE's. I need to fit it in my partners GMC Yukon. However it has to go on it's side. Anyone know? Give me a holler back please. |
Post# 344525 , Reply# 4   4/24/2009 at 11:42 (5,478 days old) by turquoisedude (.)   |   | |
I try to avoid transporting any kind of a washer on it's side or back, David. A good, vintage Filter-Flo has a pretty intricate suspension system that you could knock out of alignment if you're not careful. It may run the cost of acquistion up a bit, but it's worth renting a larger truck or a trailer if you have to. I've had to transport a dryer on it's back and I was lucky - but there too, you could knock the drum out of it's mounting. |
Post# 344567 , Reply# 5   4/24/2009 at 17:17 (5,477 days old) by iheartmaytag (Wichita, Kansas)   |   | |
Post# 344578 , Reply# 6   4/24/2009 at 19:16 (5,477 days old) by tristarcxl ()   |   | |
While the cable suspension is definitely a concern, I'd be more worried about tearing up the rubber boot on the bottom of the tub! Carry it upright for sure. |
Post# 344643 , Reply# 7   4/25/2009 at 05:48 (5,477 days old) by sactoteddybear ()   |   | |
I just sent you an E-Mail, please contact me. Peace and Kind Regards, Steve SactoTeddyBear... |
Post# 344663 , Reply# 8   4/25/2009 at 10:07 (5,477 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 344676 , Reply# 9   4/25/2009 at 12:47 (5,477 days old) by jons1077 (Vancouver, Washington, USA)   |   | |
I was able to move my old filter-flo on it's side. It actually fit inside a Ford Explorer on its side along with the dryer. Just the washer would definitely fit. There was no damage to the suspension or boot and you can still buy a boot just in case. There are still plenty of parts out there for these washers. Enjoy! Jon |
Post# 344936 , Reply# 10   4/26/2009 at 12:27 (5,476 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 345128 , Reply# 11   4/27/2009 at 17:15 (5,474 days old) by bobbyderegis (Boston)   |   | |
I would be concerned with the weight. The cement block inside it makes the GE FF quite heavy. Bobby in Boston |
Post# 345131 , Reply# 12   4/27/2009 at 17:44 (5,474 days old) by yogitunes (New Jersey)   |   | |
I have picked up too many to count washers and dryers in my Jeep Cherokee, laid on sides front but mostly the back, it was just easier to tilt against vehicle and then lift from bottom and slide in...and never had an issue with anything going wrong....just some water may spill out...keep a few towels nearby and lay it on an old blanket...and keep in mind that it may slide so you may want to "block" it...the only machine i was told to keep upright was my neptune...and that advise came from a maytag repairman...happy motoring
