Thread Number: 22080
My New Old Maytags! |
Post# 346270   5/3/2009 at 15:14 (5,464 days old) by autowasherfreak ()   |   | |
I finally have vintage washer and dryer set Maytag 606's. Thanks to Al, and Mike! I haven't done a video yet but here are some pictures. |
Post# 346271 , Reply# 1   5/3/2009 at 15:15 (5,464 days old) by autowasherfreak ()   |   | |
Money shot. |
Post# 346272 , Reply# 2   5/3/2009 at 15:16 (5,464 days old) by autowasherfreak ()   |   | |
Matching dryer. |
Post# 346273 , Reply# 3   5/3/2009 at 15:17 (5,464 days old) by autowasherfreak ()   |   | |
Dryer 2 |
Post# 346276 , Reply# 5   5/3/2009 at 15:23 (5,464 days old) by autowasherfreak ()   |   | |
Here's a shot of the motor and pump. |
Post# 346286 , Reply# 6   5/3/2009 at 16:36 (5,464 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 346300 , Reply# 7   5/3/2009 at 18:14 (5,464 days old) by qsd-dan (West)   |   | |
Yep, 806's not 606's. You also have the rare stainless lint filter. Looking at the pic, it appears that the tub clamp is bent. You'll probably need to get a new one or steal a good one from a donor machine. The same clamps were used in all small and tall tub machines from the late 50's through the early to mid 90's. New tub clamps are expensive, around $50. |
Post# 346351 , Reply# 8   5/3/2009 at 22:05 (5,463 days old) by swestoyz (Cedar Falls, IA)   |   | |
Post# 346352 , Reply# 9   5/3/2009 at 22:09 (5,463 days old) by gadgetgary (Bristol,CT)   |   | |
Post# 346353 , Reply# 10   5/3/2009 at 22:18 (5,463 days old) by swestoyz (Cedar Falls, IA)   |   | |
Post# 346358 , Reply# 11   5/3/2009 at 22:41 (5,463 days old) by qsd-dan (West)   |   | |
Post# 346361 , Reply# 12   5/3/2009 at 22:46 (5,463 days old) by gadgetgary (Bristol,CT)   |   | |
Post# 346362 , Reply# 13   5/3/2009 at 22:49 (5,463 days old) by gadgetgary (Bristol,CT)   |   | |
Post# 346363 , Reply# 14   5/3/2009 at 22:51 (5,463 days old) by qsd-dan (West)   |   | |
Post# 346367 , Reply# 16   5/3/2009 at 23:06 (5,463 days old) by swestoyz (Cedar Falls, IA)   |   | |
Couple of things - Square non-serviceable motors were mixed with round serviceable motors starting, IIRC, in 73 or 74. A trip to the archives can confirm this. It is very possible to see original square motors on early 70's machines. A nice way to see if the motor is original to the machine is to decode the two letters on the MAYTAG label. For instance, Gary's example above shows that motor with an August '73 build and would consequentially match within a month or two of the machine build month/year. Also - the pump doesn't have the injector hose running from the dispenser container to the pump. The right handed rubber dispensers did not have a lid bumper on the right hand side, and instead acted as the bumper. Jim - do you have any photos of the model tags? Regardless of the questions you still have a beautiful set! Ben |
Post# 346368 , Reply# 17   5/3/2009 at 23:06 (5,463 days old) by qsd-dan (West)   |   | |
Post# 346369 , Reply# 18   5/3/2009 at 23:09 (5,463 days old) by gadgetgary (Bristol,CT)   |   | |
Post# 346370 , Reply# 19   5/3/2009 at 23:10 (5,463 days old) by qsd-dan (West)   |   | |
"Also - the pump doesn't have the injector hose running from the dispenser container to the pump. The right handed rubber dispensers did not have a lid bumper on the right hand side, and instead acted as the bumper" DOH!! How did I miss those? I guess I'll drag myself to the corner for a "Time Out" LOL!! |
Post# 346373 , Reply# 20   5/4/2009 at 00:07 (5,463 days old) by autowasherfreak ()   |   | |
Here is the model plate on the washer. |
Post# 346374 , Reply# 21   5/4/2009 at 00:07 (5,463 days old) by autowasherfreak ()   |   | |
Dryer plate |
Post# 346375 , Reply# 22   5/4/2009 at 00:09 (5,463 days old) by autowasherfreak ()   |   | |
Cycle selector |
Post# 346376 , Reply# 23   5/4/2009 at 00:10 (5,463 days old) by autowasherfreak ()   |   | |
Load size |
Post# 346377 , Reply# 24   5/4/2009 at 00:11 (5,463 days old) by autowasherfreak ()   |   | |
Water Temp |
Post# 346379 , Reply# 25   5/4/2009 at 00:12 (5,463 days old) by qsd-dan (West)   |   | |
Post# 346380 , Reply# 26   5/4/2009 at 00:13 (5,463 days old) by autowasherfreak ()   |   | |
Speed selection |
Post# 346383 , Reply# 27   5/4/2009 at 00:24 (5,463 days old) by revvinkevin (Tinseltown - Shakey Town - La-La Land)   |   | |
Hey Jim, wow, your camera focuses up close, nice! So you have a gas 806 dryer and... it would appear you have an A606 washer which, as Dan said, someone went to A LOT of trouble to put an A806-S control panel on! The 806 was the only model of this era with the lighted control panel, the 606 did not. What is the two letter code at the end of the serial number? Is that OB or QB?? You have the suds saver control panel, but you do not appear to have the suds saver machine underneath. While I don't know exactly what a "suds" machine looks like inside, I do know there should be some sort of "valve' in the outlet hose from the pump and two hoses out of the machine from there. |
Post# 346390 , Reply# 29   5/4/2009 at 01:44 (5,463 days old) by qsd-dan (West)   |   | |
Post# 346513 , Reply# 31   5/4/2009 at 16:55 (5,463 days old) by qsd-dan (West)   |   | |
Post# 346518 , Reply# 33   5/4/2009 at 17:35 (5,463 days old) by revvinkevin (Tinseltown - Shakey Town - La-La Land)   |   | |
Post# 346528 , Reply# 34   5/4/2009 at 18:50 (5,463 days old) by qsd-dan (West)   |   | |
Post# 346548 , Reply# 35   5/4/2009 at 20:30 (5,463 days old) by revvinkevin (Tinseltown - Shakey Town - La-La Land)   |   | |
