Thread Number: 22253
A806 vs. A606 |
Post# 348529   5/12/2009 at 23:35 (5,460 days old) by washerfan ()   |   | |
What are the main differences between these two Maytag models? |
Post# 348535 , Reply# 1   5/13/2009 at 00:05 (5,460 days old) by lebron (Minnesota)   |   | |
The 606 didn't have seperate spin/wash speeds, just RA or GA. It didn't have a rinse temp selector. It didn't have a prewash cycle. It didn't have a tub light or console light. It didn't have the timed bleach injector. It didn't have the metal piece of trim on the front panel. I'm sure I've missed something but others will add on.
Post# 348537 , Reply# 2   5/13/2009 at 00:10 (5,460 days old) by washerfan ()   |   | |
Well see I have a chance to get a matched A606 and DE606. I would really rather get the 806 versions. I am not sure what I am going to do. |
Post# 348539 , Reply# 3   5/13/2009 at 00:13 (5,460 days old) by qsd-dan (West)   |   | |
Post# 348541 , Reply# 4   5/13/2009 at 00:17 (5,460 days old) by 70series ( Connecticut.)   |   | |
The only light the 606 had on some of its models was the little pilot light that was merely a dot above the dial, and was activated when the knob was pulled out. Have a good one, James |
Post# 348552 , Reply# 5   5/13/2009 at 01:21 (5,460 days old) by washerfan ()   |   | |
Is there a difference in tub size? What are the tub sizes? |
Post# 348556 , Reply# 6   5/13/2009 at 01:34 (5,460 days old) by lebron (Minnesota)   |   | |
Post# 348557 , Reply# 7   5/13/2009 at 01:38 (5,460 days old) by qsd-dan (West)   |   | |
Same size tub as the 806. Starting in 1966, Maytag offered a larger tub in certain models (19 pounds if I recall correctly). Before 1966, ALL tubs were the same 16 pound size whether BOL or TOL and everywhere in between. The difference between the small and large tubs is that the large tub is a wee deeper than 2 inches. Both tubs are the same diameter, thus use the same hardware with the exception of the outer tub braces.
Post# 348558 , Reply# 8   5/13/2009 at 01:44 (5,460 days old) by washerfan ()   |   | |
So about 3 cubic feet? |
Post# 348559 , Reply# 9   5/13/2009 at 01:49 (5,460 days old) by lebron (Minnesota)   |   | |
Post# 348579 , Reply# 10   5/13/2009 at 06:12 (5,460 days old) by gadgetgary (Bristol,CT)   |   | |
Post# 348581 , Reply# 11   5/13/2009 at 06:18 (5,460 days old) by gadgetgary (Bristol,CT)   |   | |
Post# 348582 , Reply# 12   5/13/2009 at 06:21 (5,460 days old) by gadgetgary (Bristol,CT)   |   | |
Post# 348584 , Reply# 13   5/13/2009 at 06:25 (5,460 days old) by gadgetgary (Bristol,CT)   |   | |
Post# 348587 , Reply# 14   5/13/2009 at 06:46 (5,460 days old) by gadgetgary (Bristol,CT)   |   | |
Post# 348588 , Reply# 15   5/13/2009 at 06:46 (5,460 days old) by washerfan ()   |   | |
Those are beutiful machines you have. I still wonder what the tub size is though. Also, could I easily wash a queen-sized bed comforter in it? How about small bathroom rugs? |
Post# 348602 , Reply# 16   5/13/2009 at 07:59 (5,460 days old) by swestoyz (Cedar Falls, IA)   |   | |
Check out this archived link - discusses the differences between all the 'new' '06 models. Ben CLICK HERE TO GO TO swestoyz's LINK |
Post# 348674 , Reply# 18   5/13/2009 at 16:21 (5,460 days old) by autowasherfreak ()   |   | |
Does anyone have or know where I can get an instruction manual my 806 washer and dryer? I need the dryer manual more so than the washer so I can figure out how to light the pilot light. |
