Thread Number: 22554
Frigidaire Tub Change |
Post# 353380   5/30/2009 at 14:59 (5,438 days old) by joelippard (Hickory)   |   | |
Well guys, it's been officially determined that the tub is bad in my Rapidry 1000. The achilles heel of this solid tub has done it in -- the tub plug, it was completely rotten and allowed the cast iron filings to clump together, this explains the poor balancing and vibration issues on this machine. Fortunately, due to the kindness of other club members I have a donor machine with a good tub. The issues surrounding this are definetly not new ones. The tub nut is stuck on the donor machine and I've drowned it in PB Blaster. I'm trying to loosen it with channel locks and a rubber mallet to no avail. It should also be noted that this tub nut lacks the locking tab to hold the nut in place. Second issue, the agitator nut will not release on the Rapidry machine. The keyway on the shaft is missing as it turns all the way thru with the jetcone turning and possible wrinkling to the bellows. I put a pair of locking pliers on the agitate shaft and let it ride against the upper pump housing, it still turned thru. I spent about 5 hours on this yesterday and am stopped in my tracks by these maladies. Today, I'm tired, sore, and disheartened with the process so I must rest until I feel like working on it again. Think I'm going to have to call my Dad in to help. I'd like to think I'm still strong and independent at 35 -- I never like asking for help... Here are the pictures of where I'm currently at in the process. |
Post# 353381 , Reply# 1   5/30/2009 at 15:00 (5,438 days old) by joelippard (Hickory)   |   | |
Post# 353476 , Reply# 3   5/30/2009 at 22:53 (5,438 days old) by soberleaf ()   |   | |
what exactly is the "tub plug"? |
Post# 353483 , Reply# 4   5/30/2009 at 23:10 (5,438 days old) by joelippard (Hickory)   |   | |
If you look at photo one, the tub plug is the black thing to the right on the tub top, this is the tub's balance ring and it contains fillings that are made of cast iron. When the plug does not seal perfectly any longer moisture can enter and cause the filings to clump, this is what happened on my machine I suspect many years ago... You will see in the second photo a sink stopper in place of the tub plug that was rotten when I removed it. I was able to remove some of the filings and insert BB's in an attempt to repair the existing tub but in this case the filing are clumped up so badly this was to no avail. I wouldn't wish a project like this on anyone. I'm soaking the tub nut in PB Blaster overnight. If that damn thing doesn't come off in the morning I'm going to buy a torch and heat it's ass up! For anyone who has one of these machines you should seal the plug off using a RTV seal or Caulk, you can do this without removing the top of the machine, just rotate the tub until the plug is front center and push back on the tub to fully expose and seal the plug. The seal should be checked at least yearly and reapplied as needed. |
Post# 353488 , Reply# 5   5/30/2009 at 23:13 (5,438 days old) by joelippard (Hickory)   |   | |
Post# 353500 , Reply# 7   5/30/2009 at 23:47 (5,438 days old) by swestoyz (Cedar Falls, IA)   |   | |
Post# 353532 , Reply# 8   5/31/2009 at 08:59 (5,438 days old) by joelippard (Hickory)   |   | |
I've tried several things. I have bought a total of 3 wrenches now and they don't fit properly -- all of them will go back to the store. The problem is finding a wrench that is right diameter (which I have found out is 1 1/2 inches) that is short enough to fit down in the tub. I have been using channel locks and hitting them with a rubber mallet. I bought a torch only to find that it won't stay lit long being held upside down and it will not fit into the tub sideways either. I also discovered this morning on the rapidry machine that there is water sitting on top of the pump housing. I'm more disgusted today than I was yesterday. All I wanted to do was change a tub and I had 3 days to do it in. I'm not so sure that I have time, or the patience for this. |
Post# 353544 , Reply# 9   5/31/2009 at 09:57 (5,437 days old) by swestoyz (Cedar Falls, IA)   |   | |
The tub nut is virtually impossible to remove with the correct style of wrench. Since we no longer can walk down to our local Frigidaire dealers to get the tub nut wrench, we need to seek alternatives. Striking or Slugging wrenches will do this job. I bought the Grainger stock number 1APM9 - a 1 1/2 Proto slugging wrench. While pricey, the Proto wrench got the job done. Fits inside the tub, and you smack it with a rubber mallet. Just make sure to line the tub with towels so you don't chip the porcelain finish. Even though I now have a Frigidaire tub nut wrench I prefer to use the Proto one. It has more meat and really can get a good hit on the nut due to the sheer weight of the wrench (over 1" thick cast iron). I feel your pain. Keep working your alternatives and sooner or later you'll come out victorious. If I were in your shoes I'd order the wrench, walk away until it comes, then give it another try. A fresh mind with a fresh tool will come to the conlusion better than a fatigued one. Good luck, Ben CLICK HERE TO GO TO swestoyz's LINK |
Post# 353553 , Reply# 10   5/31/2009 at 10:41 (5,437 days old) by jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Ben is on the right track Joe! What you need is Impact not muscle. So you need to strike and not pull , a channel lock is only good for water hoses, order the impact wrench, and take a break til it arrives. Also on the agitate shaft, I'd use procedure Jetcone#19: The whole shaft and jetcones can be pulled out the top of the machine if you loosen and remove the agitate foot nut at the bottom of the tranny. Swing the agitate arm out of the way and you can pull or tap the whole shebang out of the tub. Before pulling the whole assembly out you should try to use procedure Jetcone#18: You should try to save the bellows by lifting the shaft high enough that you can block the agitator up and get a fine flat blade screw driver under there to release the bellows clamps. Then draw the bellows away from the tub lip and VOILA you can pull the sucker up and out of the machine. Now two points to add, you may have already ripped the bellows by turning the shaft so you can skip Jet#18 and if the bronze bearing is torn IE the tangs that keep the agitate shaft from turning then your mechanism is toast and you will need to tap lightly the agitate shaft out of the top (Jet#19). I say LIGHTLY as the agitate shaft is made of SOFT steel! You will pean the end if you hit too hard and then the shaft won't fit up the spin tube. Its good you found another tub. Have fun thats what its all about! Jet |
Post# 353563 , Reply# 11   5/31/2009 at 11:02 (5,437 days old) by gyrafoam (Wytheville, VA)   |   | |
A large "worm-gear" clamp is another way to get those bellows-clamps off and on again. |
Post# 353602 , Reply# 12   5/31/2009 at 14:23 (5,437 days old) by joelippard (Hickory)   |   | |
I have a Grainger store close to me, but that wrench will have to wait until I can afford it. My Dad will come help me in about 2 weeks so I think I will just leave it until then. My level of aggrivation grows by the hour. Why would I have water on the top of the pump now? I guess that's messed up now too. |
Post# 354098 , Reply# 14   6/2/2009 at 07:29 (5,436 days old) by joelippard (Hickory)   |   | |
actually was coming out of the top where the shaft enters the pump. I think the seal has been compromised from stress on the mechanism in trying to remove the agitator nut. I'm hoping it will right itself after I get everything put back together and get the machine running again, if not I'll be working on the pump too. I can see this is going to be a drawn out process. I'll be addressing every issue with the machine until it's perfect. I'm feeling better about the repairs. I was so dead set on getting it all done in 2 days. I'm a hard ass in the respect that I like things done both quickly, and perfectly. I made progress yesterday on parting out the items I'll be keeping from the donor machine. I think a guy has the wrench I need for the tub and is going to give it to me, so we'll see what comes next. |
Post# 354112 , Reply# 15   6/2/2009 at 08:59 (5,436 days old) by unimatic1140 (Minneapolis)   |   | |
Post# 354130 , Reply# 16   6/2/2009 at 12:28 (5,435 days old) by swestoyz (Cedar Falls, IA)   |   | |
Post# 354179 , Reply# 17   6/2/2009 at 16:26 (5,435 days old) by joelippard (Hickory)   |   | |
Thank you to all of you guys for your tips and advice. I very well may need more of it until this is resolved. I'm supposed to be getting a free wrench tomorrow, and Dad will come over in a few weeks -- we'll see how it goes. I'm going ahead and clean and seal the plug in the new tub tomorrow. It looks like it possibly was sealed from the factory if you notice the "stuff" around it in the picture
Post# 354471 , Reply# 19   6/3/2009 at 19:10 (5,434 days old) by joelippard (Hickory)   |   | |
Post# 354567 , Reply# 20   6/4/2009 at 04:03 (5,434 days old) by norfolksouthern ()   |   | |
I am wondering about the availability of some water and oil bellows for a 1-18. Are there some places like this that still have them? NorfolkSouthern |
Post# 354642 , Reply# 22   6/4/2009 at 13:43 (5,433 days old) by joelippard (Hickory)   |   | |
Norfolksouthern, Larry told me he didn't have any 1-18 bellows left. Bobby, thank you for your comments. I have a bit more perspective now. I was so PO'd last weekend. Dad and I haven't worked on a project in years. I think there will be some fun elements to it when we get together to work. Dad always seemed to find a way when I was growing up. I hope he hasn't lost the touch ;) |
Post# 357621 , Reply# 24   6/16/2009 at 22:08 (5,421 days old) by joelippard (Hickory)   |   | |
I'm still where I was on this project. I've been pretty busy and I'm waiting on the guy to bring me the wrench and Dad was a little sick last week. Once I get the wrench and we get the time, progress will resume. I've got another little project on the heels of this one, but much less intense and more fun. Pics will be forthcoming one day
Post# 358766 , Reply# 25   6/22/2009 at 16:32 (5,415 days old) by joelippard (Hickory)   |   | |
I finally got the wrench I needed and with four light taps of the rubber mallet the tub nut came loose. Here are the pictures of the cleaned new tub with the tub plug sealed up and ready to be installed. A picture of the donor machine and it's water container. This water container looks like new, I'm surprised given rustyness of the cabinet. Now I'm in the process of parting out the donor machine. I'll remove the mechanism and the water container this week and the carcass will go to the dump.
Post# 358767 , Reply# 26   6/22/2009 at 16:34 (5,415 days old) by joelippard (Hickory)   |   | |
Post# 358768 , Reply# 27   6/22/2009 at 16:35 (5,415 days old) by joelippard (Hickory)   |   | |
Post# 358782 , Reply# 28   6/22/2009 at 17:02 (5,415 days old) by gyrafoam (Wytheville, VA)   |   | |
Remove the spin-shaft seal (black rubber). Then remove screws in spin-shaft retainer. Mechanism should be ready to drop right out through the bottom, so be sure you brace it! |
Post# 359076 , Reply# 29   6/23/2009 at 19:37 (5,414 days old) by joelippard (Hickory)   |   | |
Post# 359810 , Reply# 30   6/26/2009 at 22:51 (5,411 days old) by soberleaf ()   |   | |
could you please post a pic of the wrench that you used so i will know what to get. also, when you refer to water container do you mean the water seal? thanks |
Post# 359822 , Reply# 31   6/26/2009 at 23:32 (5,411 days old) by joelippard (Hickory)   |   | |
