Thread Number: 22574
1967 G.E. MOBILE MAID PUMP IMPELLER IS OUT! PICS! |
Post# 353700 , Reply# 3   5/31/2009 at 20:30 (5,440 days old) by soberleaf ()   |   | |
i cut the board in half |
Post# 353701 , Reply# 4   5/31/2009 at 20:32 (5,440 days old) by soberleaf ()   |   | |
to assemble it around impeller shaft and then clamp it together using more boards, 1 by 3 lumber firing strips. |
Post# 353702 , Reply# 5   5/31/2009 at 20:33 (5,440 days old) by soberleaf ()   |   | |
here it is |
Post# 353703 , Reply# 6   5/31/2009 at 20:34 (5,440 days old) by soberleaf ()   |   | |
a nice tight fit! we like that! |
Post# 353707 , Reply# 8   5/31/2009 at 20:37 (5,440 days old) by soberleaf ()   |   | |
view |
Post# 353708 , Reply# 9   5/31/2009 at 20:38 (5,440 days old) by soberleaf ()   |   | |
rises! |
Post# 353712 , Reply# 11   5/31/2009 at 20:46 (5,440 days old) by soberleaf ()   |   | |
after impeller was lifted off shaft about 1/2 inch. i could feel it moving and it made a creaking sound with every turn of the nut! the wood was groaning a bit too! very interesting experience i must say! |
Post# 353713 , Reply# 12   5/31/2009 at 20:47 (5,440 days old) by soberleaf ()   |   | |
another view. it's comin off! |
Post# 353717 , Reply# 15   5/31/2009 at 20:54 (5,440 days old) by soberleaf ()   |   | |
drain pump housing. seal is pressed into it. the drain impeller is in the background and is the other half of the seal. both look good actually, i wonder if that was where the leak was coming from? |
Post# 353719 , Reply# 16   5/31/2009 at 20:54 (5,440 days old) by soberleaf ()   |   | |
view |
Post# 353721 , Reply# 17   5/31/2009 at 20:56 (5,440 days old) by soberleaf ()   |   | |
a bit beat up looking but actually it's just discolored. it's metal. it will shine right up with a wire brush on the drill |
Post# 353722 , Reply# 18   5/31/2009 at 20:57 (5,440 days old) by soberleaf ()   |   | |
showing water seal. obviously i won't be taking a drill to this side! |
Post# 353723 , Reply# 19   5/31/2009 at 20:58 (5,440 days old) by soberleaf ()   |   | |
that spray arms mounts to. it's in great shape. |
Post# 353724 , Reply# 20   5/31/2009 at 20:59 (5,440 days old) by soberleaf ()   |   | |
very good condition for being 42 years old! |
Post# 353727 , Reply# 22   5/31/2009 at 21:04 (5,440 days old) by soberleaf ()   |   | |
this used to intrigue me to no end when i was a kid! God only knows why?! |
Post# 353730 , Reply# 23   5/31/2009 at 21:04 (5,440 days old) by soberleaf ()   |   | |
another |
Post# 353731 , Reply# 24   5/31/2009 at 21:05 (5,440 days old) by soberleaf ()   |   | |
can't get enough! |
Post# 353732 , Reply# 25   5/31/2009 at 21:07 (5,440 days old) by soberleaf ()   |   | |
it's in great shape |
Post# 353733 , Reply# 26   5/31/2009 at 21:08 (5,440 days old) by soberleaf ()   |   | |
pretty good shape, maybe not great but usable! |
Post# 353734 , Reply# 27   5/31/2009 at 21:08 (5,440 days old) by soberleaf ()   |   | |
view |
Post# 353735 , Reply# 28   5/31/2009 at 21:09 (5,440 days old) by soberleaf ()   |   | |
again |
Post# 353736 , Reply# 29   5/31/2009 at 21:09 (5,440 days old) by soberleaf ()   |   | |
pic |
Post# 353738 , Reply# 30   5/31/2009 at 21:10 (5,440 days old) by soberleaf ()   |   | |
to bore you! |
Post# 353742 , Reply# 32   5/31/2009 at 21:14 (5,440 days old) by soberleaf ()   |   | |
that looked like nightmare before |
Post# 353746 , Reply# 35   5/31/2009 at 21:19 (5,440 days old) by soberleaf ()   |   | |
of this shaft |
Post# 353751 , Reply# 38   5/31/2009 at 21:27 (5,440 days old) by soberleaf ()   |   | |
i just love this little dishwasher! it's so classic 60's! 1967 i was told! |
Post# 353821 , Reply# 42   6/1/2009 at 08:17 (5,439 days old) by soberleaf ()   |   | |
so the best thing for a sleeve bearing is to simnply give it a good dose of 3 in one motor oil? that's what i did i this one. |
Post# 353836 , Reply# 43   6/1/2009 at 09:37 (5,439 days old) by tristarcxl ()   |   | |
Bingo. |
Post# 353838 , Reply# 44   6/1/2009 at 10:03 (5,439 days old) by dnastrau (Lords Valley, PA)   |   | |
Thanks for the lesson on sleeve bearings tristarcxl - I appreciate it! I have, in the past, used both grease and car motor oil on sleeve bearings on a couple of motors that were on their last legs. I won't be doing that again! Andrew S. |
