Thread Number: 22598
Super DD portable/parts sources |
Post# 354121 , Reply# 2   6/2/2009 at 10:45 (5,440 days old) by supremewhirlpol ()   |   | |
Now that I think of it, I may just have a DD three-speed motor. I will check later today. |
Post# 354343 , Reply# 4   6/3/2009 at 09:33 (5,439 days old) by everythingold (Grand Rapids, Michigan)   |   | |
Post# 354466 , Reply# 7   6/3/2009 at 18:50 (5,438 days old) by supremewhirlpol ()   |   | |
that connector I was talking about |
Post# 354467 , Reply# 8   6/3/2009 at 18:52 (5,438 days old) by supremewhirlpol ()   |   | |
The motor nameplate. I have only seen one type of DD three speed motor. |
Post# 354549 , Reply# 11   6/3/2009 at 23:42 (5,438 days old) by everythingold (Grand Rapids, Michigan)   |   | |
The motor pictured is the "old" style DD 3 speed. The new ones have a single wire from the harness that plugs directly into the motor. I don't think you should have any trouble finding a motor at a used appliance store, repair man service, scrap yard etc. Makes sure it spins freely and check for bearing play. hold the motor to the ground with your knee, and see if you can move the shaft either up or down, or in and out. Bearing play = bad motor. matt
Post# 357497 , Reply# 12   6/16/2009 at 13:41 (5,426 days old) by kenmoreforever ()   |   | |
Be ready to splice no matter how much you resist it. Never seen undertaking like this without at least one spice. good luck. |
Post# 358754 , Reply# 18   6/22/2009 at 15:15 (5,420 days old) by supremewhirlpol ()   |   | |
Are you sure that you did not have the speed setting on intermittent extra slow? There are 2 extra slow settings. One is intermittent(on for a few sec then off), while the other extra slow setting is constant. |
Post# 358756 , Reply# 19   6/22/2009 at 15:23 (5,420 days old) by davek ()   |   | |
it ran ok on extra slow, too. |
