Thread Number: 22627
Anyone here have a newer LG FL? |
Post# 354469   6/3/2009 at 18:59 (5,439 days old) by mark_wpduet (Lexington KY)   |   | |
Post# 354515 , Reply# 1   6/3/2009 at 21:35 (5,439 days old) by appnut (TX)   |   | |
That's very true. Todd in new Orleans uses the PP cycle for that reason for just about everything but whites & towels, then he uses either Whites or Sanitary cycles. His machine is like the 1st or 2nd generation. Many of the more recent models in the last couple of years have an option button for added water, adds a higher water level for wash & rinses than the default fill levgel. I'd check Epinions.com for reviews
Post# 354560 , Reply# 4   6/4/2009 at 01:29 (5,438 days old) by vintagesearch ()   |   | |
i think i would opt into an LG or frigidaire if we actually get a frontloader.....time will tell i think these LG ones look cool |
Post# 354647 , Reply# 5   6/4/2009 at 13:54 (5,438 days old) by mark_wpduet (Lexington KY)   |   | |
those LG's look cool too. I've been reading that the perma press and bulky or comforter cycles use more water. It never occurred to me that people could actually use these cycles for every load, but hey, why not. I know when I bought my duet 9300 a little over 4 years ago, it was one model below the TOL model, the only difference being my model didn't have as many cycles. My model lacks "bulky". It does have delicate and soak but those cycles don't agitate enough to use for regular laundry. So I'm thinking key here when buying a front load washer is to make sure the machine you buy has one of those cycles so if u need more water, it's there. I think the some of the current LG's have the water plus button, but I think all have perma press cycle. The Duet's or Hetties don't have perma press but some do have bulky. I've also read to make sure when buying a machine to make sure it's service locally. I wonder if the back ordered parts are still a problem with LG so when you need service it doesn't take weeks to get a part, meaning weeks without being able to use your machine.
Post# 356599 , Reply# 6   6/12/2009 at 18:07 (5,430 days old) by mark_wpduet (Lexington KY)   |   | |
Post# 356652 , Reply# 8   6/12/2009 at 22:42 (5,430 days old) by mark_wpduet (Lexington KY)   |   | |
I suspect that if I had this washer that is the cycle I would use for EVERYTHING! I agree about the spin, although I was thinking it would only allow "low", glad it at least allows "med". Pardon my ignorance, but what does the recirculation pump do exactly? I'm thinking all front loaders, fill for wash, drain, then spin, then fill with rinse, then spin, the fill with rinse again, then spin, unless u choose extra rinse. What is the purpose of the recirculation pump? Oh and this washer doesn't have a "water plus" button does it? I don't think it does though could be wrong. :) Thanks |
Post# 356677 , Reply# 9   6/13/2009 at 02:01 (5,429 days old) by launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Read an article years ago on front loading washer desgin and water usage. It clearly stated that once water levels fell below a certian level (say to decrease water/energy use), a recirculating pump is then required, otherwise laundry would never become clean/well rinsed. This is what the LG machine does. To keep water levels within parameters for "Energy Star" ratings, something has to keep the puny amount of water moving through laundry, as the normal method of gravity pulling water down through laundry isn't going to work with "wet nap" washing. L. |
Post# 356703 , Reply# 10   6/13/2009 at 09:15 (5,429 days old) by mrb627 (Buford, GA)   |   | |
Post# 356707 , Reply# 11   6/13/2009 at 10:13 (5,429 days old) by bajaespuma (Connecticut)   |   | |
I use the Permanent Press and SANITARY Cycles on my LG more than the others; amounts of water always seem stingy, but I can't argue with success. The only failure is when I use the "PREWASH" option on any cycle besides PP: if the machine is fully loaded with stuff like towels, there isn't enough water to wet all the laundry before it cycles into the first spin before the main wash. On the NORMAL, SANITARY and COTTONS/TOWELS the machine uses very little water, but, with the recirculating spray, everything gets wet quickly. Also, it ups the water levels for all rinse periods. Whatever cycle I use, the LG is far and away the best washing machine I've ever used in this country. As I've said many times on this site, I'm a pastry chef with weeks and weeks of really dirty clothes that would do a testing laboratory proud. No machine has been able to wash and rinse my stuff as well as the LG. I collect lots of beautiful top loaders, but don't use them for much beyond soaking because they are simply not as effective, efficient and "green" as the LG. Even when I do a load in one of my vintage machines, I always do a finishing 1200 rpm spin in the LG. I haven't tried a Miele in this country yet, but unless I can find one that has a large capacity and runs on 220v, I'm not going to switch. I'd like to buy an old-style small capacity 220v Miele, but I have no funds for "toys" right now. I've been luckier than most LG customers I think, but I'm very satisfied with this wonderful machine. The only thing they could do to improve the LG washer is to manufacture it to run on 220 so cycles would go faster and I could have a true "boil" wash when I wanted one. |
Post# 356758 , Reply# 12   6/13/2009 at 15:27 (5,429 days old) by mark_wpduet (Lexington KY)   |   | |
