Thread Number: 22639
F & P GWL 11 - Trouble in Spin Cycle |
Post# 354686 , Reply# 1   6/4/2009 at 16:51 (5,438 days old) by super32 (Blackstone Massachusetts)   |   | |
Post# 354701 , Reply# 2   6/4/2009 at 17:49 (5,438 days old) by dadoes (TX, U.S. of A.)   |   | |
Does the noise occur only during spin, that is, when the basket is rotating at 300+ RPM? Not during agitation? Not during EcoActive recirculation or neutral drain? Check the pump to eliminate (or confirm) it as a source. Get into diagnostic mode. With Power off, press and hold Wash Temp Down, then press Power at the same time. Should get two beeps and some panel lights. Release the buttons. Then press Regular cycle to turn the pump on (or off). Does the noise occur when the pump runs? If so, there may be lint or a foreign object caught in the impeller, or the pump is going bad. Turn off the Power to exit diagnostics. If the pump is the noise source, then it should (theoretically) happen at the start of a load (on all cycles except Perm Press) during the EcoActive wash period, and during drain/spin. Note: Even if the pump sounds good, I'd suggest a visual examination of it for signs of leaking just for insurance. DO NOT use the machine with a leaking pump. A wet pump can short-out and kill the controller board, which turns a $70 repair into a $200+ repair. Replacing the pump is very easy, no tools needed! If suspect a bad main bearing (not common, F&P uses good bearings) ... rotate the basket manually (as fast as you can). Noise? Set it to the final spin on Regular or Heavy cycle, with no clothes. Noise? If you want to see it spin, easiest is to raise the top deck so you can see under it with the lid closed. Open the lid, carefully pry out the two lid bumpers near the front corners. Remove the screws. Pull the tub to the left-front to help the off-balance lever (protrudes down from the control panel at the right-rear) clear the tub when the top is raised. Raise the top, close the lid. Set it to spin. Remember to pull the tub to the left-front again when lowering the top. If the noise is confirmed during basket rotation/spin, and not related to the pump, then there could be a foreign object or a piece of clothing (sock, wash cloth) under the basket. Another possibility is a problem with the basket drive coupler. Broken, or clogged with lint/debris causing the basket to slip. The agitator and basket are driven directly by the motor shaft, no transmission. The basket sits on a toothed coupler, the agitator bolts atop that directly to the drive shaft. When the machine fills, air is trapped beneath the basket in a molded air dome, causing it float upward and disengage from the coupler so the agitator can oscillate separately. When the water drains, the basket settles back down on the coupler to spin as a unit with the agitator. The drive motor pulses clockwise and CCW a few times before spin so the electronics can confirm by way of rotational inertia that the basket is down. If the drive coupler is broken or the basket is slipping on it, spin would be noisy and lethargic. Removing the inner basket to check the coupler or for something caught under it is not difficult. |
Post# 355595 , Reply# 5   6/8/2009 at 13:42 (5,434 days old) by dadoes (TX, U.S. of A.)   |   | |
