Thread Number: 22712
Maytag 806 Agitation Problem |
Post# 355620 , Reply# 1   6/8/2009 at 15:59 (5,434 days old) by supremewhirlpol ()   |   | |
I don't work on Maytags very often, but did you clean the pulleys before putting on the new belts? |
Post# 355637 , Reply# 3   6/8/2009 at 16:56 (5,434 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
Post# 355647 , Reply# 4   6/8/2009 at 17:50 (5,434 days old) by autowasherfreak ()   |   | |
I was able to lube the right slide, but couldn't get to the left slide the side panel is in the way. |
Post# 355649 , Reply# 5   6/8/2009 at 17:57 (5,434 days old) by qsd-dan (West)   |   | |
Post# 355651 , Reply# 6   6/8/2009 at 18:16 (5,434 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 355658 , Reply# 7   6/8/2009 at 18:33 (5,434 days old) by autowasherfreak ()   |   | |
Dan is this the contents of the kit you are talking about? |
Post# 355659 , Reply# 8   6/8/2009 at 18:34 (5,434 days old) by autowasherfreak ()   |   | |
and these |
Post# 355661 , Reply# 9   6/8/2009 at 18:43 (5,434 days old) by yogitunes (New Jersey)   |   | |
Post# 355665 , Reply# 10   6/8/2009 at 19:02 (5,434 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 355718 , Reply# 12   6/9/2009 at 02:00 (5,434 days old) by qsd-dan (West)   |   | |
Post# 355719 , Reply# 13   6/9/2009 at 02:07 (5,434 days old) by qsd-dan (West)   |   | |
"There's a extra slot for a 3rd spring, I have on ocassion put a 3rd one on there, is this not advised, sometimes it seemed to slip too much, even after cleaning, for most part worked better...just wondered if I was doing damage to the machine..." You shouldn't need the 3rd spring. It won't hurt the machine, but it'll probably reduce the life of the motor and transmission belt a little bit. |
