Thread Number: 22769
westinghouse Washer help |
Post# 356390   6/11/2009 at 22:35 (5,403 days old) by oldappliancenut ()   |   | |
Does the bottom front cover come off to work on them and if so how???? |
Post# 356398 , Reply# 1   6/11/2009 at 22:51 (5,403 days old) by frapdoodle ()   |   | |
that is a beautiful machine. and i am not sure, but i think the back cover comes off to reveal the pully system and all that jazz. if im wrong then call me an idiot.......not kidding |
Post# 356400 , Reply# 2   6/11/2009 at 22:53 (5,403 days old) by oldappliancenut ()   |   | |
right in the front where I can't see it and the boot is fine no holes |
Post# 356459 , Reply# 3   6/12/2009 at 06:14 (5,403 days old) by christfr (st louis mo)   |   | |
Post# 356467 , Reply# 4   6/12/2009 at 07:02 (5,402 days old) by turquoisedude (.)   |   | |
Post# 356488 , Reply# 5   6/12/2009 at 09:06 (5,402 days old) by oldappliancenut ()   |   | |
boot is great but the door is bad |
Post# 356494 , Reply# 6   6/12/2009 at 09:31 (5,402 days old) by oldappliancenut ()   |   | |
its a bad hose....is there anyone here I could call about help on working on this......the hose is hard and no idea how to get it off......crazeedude1974@gmail.com |
Post# 356500 , Reply# 7   6/12/2009 at 09:59 (5,402 days old) by turquoisedude (.)   |   | |
Post# 356624 , Reply# 8   6/12/2009 at 20:22 (5,402 days old) by oldappliancenut ()   |   | |
tub sump and pump its leaking and its hard as a rock |
Post# 356629 , Reply# 9   6/12/2009 at 20:46 (5,402 days old) by oldappliancenut ()   |   | |
It broke when I squeezed the hose clamp....but its not a regular hose now what ???? :( |
Post# 356673 , Reply# 10   6/13/2009 at 01:16 (5,402 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
Post# 356699 , Reply# 11   6/13/2009 at 08:34 (5,401 days old) by oldappliancenut ()   |   | |
is the end that goes into the tub.....its knotched.....the rest broke like glass but the other end was like a regular hose |
Post# 356717 , Reply# 12   6/13/2009 at 12:12 (5,401 days old) by panthera (Rocky Mountains)   |   | |
We need some more pics. The good news is, Westinghouse in that period used a lot of very standard dimensions and normal plumbing components. If push comes to shove, you can use a hi-temp epoxy to attach a brass hose-connector to the drum and then - carefully looping the new hose to cope with vibration - solve the problem. But a few more pics would help. Thanks By the way, be careful taking any side panels off. Westinghouse had this thing with anchoring thermostats and thinner wires to the struts spanning between the front and the rear of their slant-fronts. A nice surprise if you pull too hard...not. |
Post# 356818 , Reply# 13   6/13/2009 at 20:17 (5,401 days old) by alr2903 (TN)   |   | |
Is that hose similar to the one Robert changed in his Whirlpool combo? The one he posted pictures of? |
Post# 357032 , Reply# 15   6/14/2009 at 16:35 (5,400 days old) by oldappliancenut ()   |   | |
the bottom of the door has holes ansd lots of rust ....looks like the owner filled it by hand as there was no hook ups where it was and the fill valve was disconnected |
Post# 357064 , Reply# 16   6/14/2009 at 20:18 (5,400 days old) by oldappliancenut ()   |   | |
will this work?????? |
