Thread Number: 22796
Old style mountain stem seal VS new style stem seal kits |
Post# 356784 , Reply# 1   6/13/2009 at 17:48 (5,428 days old) by redcarpetdrew (Fairfield, CA)   |   | |
The newer style mounting stem and seal doesn't last as long as the older ones due to them going to a lip seal for the agitator shaft. The older one with the washer and separate agitator seal just worked better. As stated on a separate thread, you can use the newer style stem with the older style agitator seal which will give you double the seal. RCD CLICK HERE TO GO TO redcarpetdrew's LINK |
Post# 356820 , Reply# 2   6/13/2009 at 20:24 (5,428 days old) by scrubflex (bronx, new york)   |   | |
RCD, check out the Maytag washer water leak thread for my request for your expert advice. |
