Thread Number: 22847
still asking that agitating question? |
Post# 357451   6/16/2009 at 11:55 (5,425 days old) by kenmoreforever ()   |   | |
How do you put a Kenmore agitator back togethyer as in top and bottom parts after they have been sperated from each other? I know how to replace the dogs just fine. |
Post# 357486 , Reply# 2   6/16/2009 at 13:27 (5,425 days old) by toploader1984 ()   |   | |
repair |
Post# 357489 , Reply# 3   6/16/2009 at 13:30 (5,425 days old) by toploader1984 ()   |   | |
some agitators do not have a rubber seal at the bottom, mine had a plastic washer that went between the corckscrew and the base of the agitator. |
Post# 357537 , Reply# 5   6/16/2009 at 16:44 (5,425 days old) by yogitunes (New Jersey)   |   | |
would this be an agitator thats called a TRIPLE?...usually found in kenmores only...it has a spring inside that allows the auger to "bounce" up and down as it washes...that i believe is only one that is different from all the rest....other than that they all go together the same way....with your eyes closed!...
