Hi,I have a maytag de750 dryer and I am looking for a wiring diagram to help diagnose a problem with it.The dryer was running fine and then it made a loud buzzing noise.It turns out the buzzing noise was coming from the bell relay that should only ring once. Now the only thing that works is the light behind the lint screen. I checked the two wire limit switch on the blower housing and it was open so i jumped it out but still noting. I also tried jumping the door switch and still no luck. I am not sure what to check on the controaler and the motor has more wires than i'm used to seeing on a single speed motor. any help would be greatly appreciated.
Thank You kdlott
Post# 359323 , Reply# 1   6/24/2009 at 21:38 (5,412 days old) by qsd-dan(West)
Here ya go! This is the best I could do. The actual schematic in the manual is pretty damn small. Hope this helps! Keep us informed.....and, oh yeah, WE NEED PICS!!!!
