Thread Number: 23038
Maytag DE 750 help |
Post# 359832 , Reply# 1   6/27/2009 at 00:25 (5,410 days old) by qsd-dan (West)   |   | |
Post# 359855 , Reply# 2   6/27/2009 at 01:25 (5,410 days old) by qsd-dan (West)   |   | |
I have been looking through my stash of info and came up with this flow chart. The DE-750 is pretty much identical to the 906 (same control switch, electronic control box, ect), which shares similar circuits with the 606 and 806 models Take a look at "Dryer Will Not Run -- DE-DG606, 806, & 906" flow chart. The numbers in the box represent the terminals to ohm out. Unplug the dryer during these tests!!! Also, you may want to check the carbon brush that makes contact with the slip ring. It may be worn out by now. |
Post# 359887 , Reply# 3   6/27/2009 at 06:16 (5,410 days old) by toggleswitch2 ()   |   | |
This is probably way too obvious, but... If all else fails woudld a momentary contact switch installed that jumps the two temminals you manually jumped be of service to you? |
Post# 360248 , Reply# 5   6/28/2009 at 20:30 (5,408 days old) by qsd-dan (West)   |   | |
I'll keep digging for more info. Seems like most of my info is either too old or too new. I do know the part# for the switch by heart.....302271. Finding a new switch will be a serious task though. Most appliance places don't have that model on hand for some reason (probably age), so just tell them it's for a DE906....same exact switch. I did have the bell buzz on my DE750 once (and I felt it pulse through the button) when I selected a "Regular Dry" and one of the other buttons was half way pushed in. Freak me out for a second, but luckily no harm was done. |
Post# 360263 , Reply# 6   6/28/2009 at 21:11 (5,408 days old) by kdlott ()   |   | |
the part number i see on it looks like 3-2271.maybe the buzzing bell messed the switch up because they are linked by a piece of wire. |
Post# 360273 , Reply# 7   6/28/2009 at 21:42 (5,408 days old) by qsd-dan (West)   |   | |
Post# 360290 , Reply# 8   6/28/2009 at 23:04 (5,408 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
