Thread Number: 23099
Combo Crisis!
Post# 360626   6/30/2009 at 12:20 (5,404 days old) by turquoisedude (.)
turquoisedude's profile picture
So picture this - it is the last day of a short vacation break that has been wonderfully relaxing; you've just finished brunch where you served the best batch of waffles you've ever made; you go to pop the dirty dishes into your fabulous vintage GE dishwasher and you step in a puddle of water...
I freaked. I thought that the patched-up drain sump of the 56 pull-out had given up on me. I took the front off the dishwasher and investigated, but found nothing... I checked supply and drain pipes - nothing! I mopped up the water and in about 20 minutes, another puddle had accumulated. So, I checked the ungodly mess of pipes under the sink. Everything seemed fine until I noticed a drip on the right bottom corner of the 562N1 combo...
Post# 360627 , Reply# 1   6/30/2009 at 12:23 (5,404 days old) by turquoisedude (.)
and there it was...
The hot water connection was the culprit... I tried to preserve the original copper supply pipes that came with the unit, but I noticed that when I took it apart and when I put it back together that the screw fitting never seemed to line up evenly. The photo shows what it looked like after I tried to tighten it up. Still not even...
Post# 360629 , Reply# 2   6/30/2009 at 12:26 (5,404 days old) by turquoisedude (.)
So, the combo is going to have to come out... eventually
And I will replace the original copper supply pipes with flexible ones.
I am not rushing, though. Why, you ask??
'Cause I finally found a cycling thermostat for the dryer!!!
I can't believe that I got one from Modern Parts in Ohio...
So, I must once again say THANK YOU!!! to gansky1 and soberleaf for sharing this place with all of us. I may still need some wiring diagram information, but gentlemen, the GE combo is yet another step closer to coming back to life fully!!
Post# 360682 , Reply# 3   6/30/2009 at 17:01 (5,404 days old) by ronhic (Canberra, Australia)
ronhic's profile picture
At least you know where the water is coming from....and that is at LEAST half the battle....
Post# 360708 , Reply# 4   6/30/2009 at 19:46 (5,403 days old) by jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)
Amen to what Ronhic said
jetcone's profile picture
finding it is half the battle!
