Thread Number: 23104
QUESTIONS FOR THE 1-18 FRIGIDAIRE EXPERTS |
Post# 360653 , Reply# 1   6/30/2009 at 14:50 (5,405 days old) by soberleaf ()   |   | |
also, the one right above the left side end of the arm. |
Post# 360710 , Reply# 7   6/30/2009 at 19:56 (5,405 days old) by jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 360739 , Reply# 10   6/30/2009 at 21:47 (5,405 days old) by soberleaf ()   |   | |
and so is the old seal |
Post# 360741 , Reply# 11   6/30/2009 at 21:48 (5,405 days old) by soberleaf ()   |   | |
that took so long to get off |
Post# 360742 , Reply# 12   6/30/2009 at 21:49 (5,405 days old) by soberleaf ()   |   | |
old water seal |
Post# 360743 , Reply# 13   6/30/2009 at 21:50 (5,405 days old) by soberleaf ()   |   | |
and motor comes next |
Post# 360744 , Reply# 14   6/30/2009 at 21:51 (5,405 days old) by soberleaf ()   |   | |
now i am going to clean and paint this outer tub |
Post# 360748 , Reply# 15   6/30/2009 at 21:57 (5,405 days old) by soberleaf ()   |   | |
where the opening is for the drain pump collection cup (back center of pic). it's not that bad yet but there was evidence of leakage in this area. |
Post# 360749 , Reply# 16   6/30/2009 at 21:59 (5,405 days old) by soberleaf ()   |   | |
problem better in this picture, in the back right corner. i've had worse problems with my dishwashers so i'm not worried about fixing it, it will be easy! |
Post# 360752 , Reply# 17   6/30/2009 at 22:06 (5,405 days old) by soberleaf ()   |   | |
i would go ahead and replace the spin bearings while i am at it. so far no luck. if anyone knows of any please let me know. or are they a standard size i could get from a bearing company? |
Post# 360753 , Reply# 18   6/30/2009 at 22:08 (5,405 days old) by soberleaf ()   |   | |
next thing to take off is the pump |
Post# 360754 , Reply# 19   6/30/2009 at 22:10 (5,405 days old) by soberleaf ()   |   | |
and all pump parts and hoses are in the tub for safe keeping |
Post# 360756 , Reply# 20   6/30/2009 at 22:13 (5,405 days old) by soberleaf ()   |   | |
the top port where the pressure switch hose connects to is broken off but that will be an easy fix too. i will drill it out and put a tube in and cement it in good. |
Post# 360757 , Reply# 21   6/30/2009 at 22:14 (5,405 days old) by soberleaf ()   |   | |
of this chamber |
Post# 360759 , Reply# 23   6/30/2009 at 22:19 (5,405 days old) by soberleaf ()   |   | |
fine. i am going to oil bearings while it's off. anyone know where to get a belt should i ever need one? |
Post# 360808 , Reply# 30   7/1/2009 at 04:28 (5,405 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 360838 , Reply# 31   7/1/2009 at 09:16 (5,404 days old) by everythingold (Grand Rapids, Michigan)   |   | |
Post# 360894 , Reply# 33   7/1/2009 at 12:33 (5,404 days old) by swestoyz (Cedar Falls, IA)   |   | |
I personally haven't pulled a 1-18 bearing, but they look 'standard' and, more than likely, could be crossed over to an alternate. Post the number that is stamped off the upper bearing and I'll see if I can find an alternate through Grainger, etc. There are two bearnings - and upper and a lower. I'd hazzard a guess that they would need to be pressed out/pressed in from the looks of it. |
Post# 360898 , Reply# 34   7/1/2009 at 12:40 (5,404 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
There was a special tool from Robinair sold to help remove the agitate shaft coupler from the shaft and the agitate arm. If you don't need to remove it for replacement, leave it alone. You really don't want to dig up another problem with an NLA part that doesn't need to be disturbed. The tool was used to hold the body of the coupler and then a wrench to un-thread it from the end of the shaft. If you remove the bearings, you should be able to get them at your local bearing/machine parts supply house - see your yellow pages. The one you pictured looks like a New Departure or similar brand bearing and there are numbers along the sides that will indicate the sizes for replacement. Even if the numbers are not fully legible, take the bearing to the shop with you (as you should in any case) and the salesperson can measure it inside and out and get the replacements for you. It would be shocking if this weren't a standard-sized bearing as custom bearings are very expensive and when profit is the motive in building appliances (all evidence having been to the contrary at GM Frigidaire) standard parts were utilized whenever possible. Best of luck! |
