Thread Number: 23278
frigidaire Rapidry 1000 find |
Post# 363116   7/11/2009 at 00:48 (5,402 days old) by oldappliancenut ()   |   | |
Heres a shot of the control panel more to follow later as I clean it up more |
Post# 363117 , Reply# 1   7/11/2009 at 00:48 (5,402 days old) by oldappliancenut ()   |   | |
has the dispencers which I thought was kewl |
Post# 363133 , Reply# 2   7/11/2009 at 04:11 (5,402 days old) by frigilux (The Minnesota Prairie)   |   | |
Post# 363149 , Reply# 3   7/11/2009 at 07:42 (5,402 days old) by gyrafoam (Wytheville, VA)   |   | |
Absolutely faaaaaahbulous Rollermatic!!!!!!!! Congratulations!!!!!!!!! |
Post# 363160 , Reply# 4   7/11/2009 at 08:48 (5,402 days old) by appnut (TX)   |   | |
Post# 363164 , Reply# 5   7/11/2009 at 08:57 (5,402 days old) by oldappliancenut ()   |   | |
a dry and and so far it works |
Post# 363167 , Reply# 6   7/11/2009 at 09:10 (5,402 days old) by davy1063 (Pennsylvania)   |   | |
a 1967 Custom Imperial. I have the same one in Turquoise. |
Post# 363174 , Reply# 7   7/11/2009 at 10:09 (5,402 days old) by everythingold (Grand Rapids, Michigan)   |   | |
Post# 363204 , Reply# 8   7/11/2009 at 12:04 (5,402 days old) by joelippard (Hickory)   |   | |
Post# 363208 , Reply# 9   7/11/2009 at 12:16 (5,402 days old) by autowasherfreak ()   |   | |
Awesome! I love that control panel! |
Post# 363306 , Reply# 11   7/11/2009 at 20:17 (5,401 days old) by oldappliancenut ()   |   | |
Pete I was just gonna ask about one |
Post# 363313 , Reply# 12   7/11/2009 at 20:39 (5,401 days old) by oldappliancenut ()   |   | |
the water bellow is bad should I continue to remove the whole tub and see how it is or just leave it alone???? |
Post# 363322 , Reply# 13   7/11/2009 at 21:07 (5,401 days old) by joelippard (Hickory)   |   | |
As long as the side of the tub looks good and the water container looks good and there are no other visual or audible problems there is no need to remove the tub. Excess lint buildup on the outside of the tub or crud in the bottom of the water container can be removed with a brush. A good overflow of the tub to partially fill the water container and then a soak before you let it spin the water out might be a good thing if it appears to need it.
Post# 363333 , Reply# 14   7/11/2009 at 22:36 (5,401 days old) by oldappliancenut ()   |   | |
I have to remove the tub theres things caught down in there and I cannont pull it out with a needle nose plyers...so any help with removing the inner tub would be great...the bellows are all off already |
Post# 363336 , Reply# 15   7/11/2009 at 22:49 (5,401 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
Post# 363347 , Reply# 17   7/11/2009 at 23:23 (5,401 days old) by joelippard (Hickory)   |   | |
What kinds of things are down in there? I was able to push my tub to the side with one hand and reach all the way to the bottom with the other. The tech talk describes removing the tub, but I'd do whatever I had to to keep from it. I had no choice my balance ring plug leaked and the granules clumped together so it wouldn't balance or spin smoothly.
Post# 363348 , Reply# 18   7/11/2009 at 23:33 (5,401 days old) by oldappliancenut ()   |   | |
gauze got down under the water bellow and its alot i got some but not all |
Post# 363350 , Reply# 19   7/11/2009 at 23:42 (5,401 days old) by swestoyz (Cedar Falls, IA)   |   | |
Very nice machine Brian - no money shot though? ;-) Did you leave the 15 series KA behind? If you need to remove the wash tub make sure you have a 1-1/2" slugging wrench to remove the tub nut. Also - the water bellows from a 1-18 washer WILL NOT fit a 1965-1969 Rollermatic. Make sure that your source knows the difference, if not - the hole in the top should be a 'D', as the 1-18 water bellows has a completely round pulsator shaft hole, let alone being taller than the earlier Uni/Multi/Rollermatic water bellows. Ben CLICK HERE TO GO TO swestoyz's LINK |
Post# 363351 , Reply# 20   7/11/2009 at 23:49 (5,401 days old) by oldappliancenut ()   |   | |
was scrapped I asked and the washer is in many peices LOL...I found the bellows from a local collector |
Post# 363414 , Reply# 23   7/12/2009 at 12:15 (5,401 days old) by everythingold (Grand Rapids, Michigan)   |   | |
Post# 363508 , Reply# 25   7/12/2009 at 18:49 (5,400 days old) by norfolksouthern ()   |   | |
How do you people get all these Rollermatics? I just don't seem to have luck finding anything around these parts. NorfolkSouthern |
Post# 363594 , Reply# 27   7/12/2009 at 23:53 (5,400 days old) by norfolksouthern ()   |   | |
I guess I'll need to invest in a Frigidaire divining rod! NorfolkSouthern |
Post# 363768 , Reply# 28   7/13/2009 at 19:02 (5,399 days old) by soberleaf ()   |   | |
now i lay me down to snooze a 1-18 i sure could use i pray the lord to make one mine if not a rollermatic will do just fine! |
Post# 363799 , Reply# 29   7/13/2009 at 21:32 (5,399 days old) by rickr (.)   |   | |
Post# 363813 , Reply# 30   7/13/2009 at 22:12 (5,399 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
Post# 363823 , Reply# 31   7/13/2009 at 23:55 (5,399 days old) by oldappliancenut ()   |   | |
shots with hols lol ....at least I know where the leak is....and I didn't use a slugging wrench ....I use a channel lock came off very easy about 6 hits....so what should I use to seal the holes???? |
Post# 363824 , Reply# 32   7/13/2009 at 23:57 (5,399 days old) by oldappliancenut ()   |   | |
shot |
Post# 363825 , Reply# 33   7/13/2009 at 23:58 (5,399 days old) by oldappliancenut ()   |   | |
pic |
Post# 363855 , Reply# 34   7/14/2009 at 07:40 (5,399 days old) by gyrafoam (Wytheville, VA)   |   | |
Yeah! I told 'ya so! Well, I'm glad to see you got to the root of the problem and are restoring this machine to its former self. I know this will be a great machine for your collection! |
Post# 364031 , Reply# 35   7/14/2009 at 23:57 (5,398 days old) by oldappliancenut ()   |   | |
I use to paint the bottom of the tub after I fix the holes???? |
