Thread Number: 23368
MayTag A806 Washer Top cover leak |
Post# 364227 , Reply# 1   7/15/2009 at 14:35 (5,397 days old) by kenwashesmonday (Carlstadt, NJ)   |   | |
I had to use a very small bead of silicone on mine. Ken D. |
Post# 364237 , Reply# 2   7/15/2009 at 15:16 (5,397 days old) by qsd-dan (West)   |   | |
Post# 364239 , Reply# 3   7/15/2009 at 15:26 (5,397 days old) by swestoyz (Cedar Falls, IA)   |   | |
Under normal circumstances a foreign sealer is not needed (i.e. silicone). Get a new seal and make sure you tighten the screws very tight on the clamp. I take a pair of pliers and hold the clamp while turning the screw with a large slotted driver; repeat for the other clamp. I usually tighten them a little bit at a time, working between both making sure the seal is positive around the tub, instead of being stronger on one side than the other. Good luck, Ben |
