Thread Number: 23411
Maytag Motor Glides and Springs Problem |
Post# 364965 , Reply# 1   7/17/2009 at 19:27 (5,394 days old) by yogitunes (New Jersey)   |   | |
are you sure the belts are on right...the main drive belt goes on first to the top slot and then the pump belt... also, do you have the pump belt too tight...this will cause the motor to pull towards the back, and cause the drive belt to slip excessively....if you have to, take the pump belt off for a second to see if that changes the wash speed... and are you using new springs, and at least 2, I put three on mine ...just some thoughts.... |
Post# 365111 , Reply# 3   7/18/2009 at 08:09 (5,394 days old) by yogitunes (New Jersey)   |   | |
Post# 365169 , Reply# 4   7/18/2009 at 13:22 (5,394 days old) by qsd-dan (West)   |   | |
Post# 365256 , Reply# 5   7/18/2009 at 22:42 (5,393 days old) by autowasherfreak ()   |   | |
I double checked the belts and they are on correctly. I tried a 3rd spring and the squeal came back during the spin until all the water was pumped out. |
Post# 366017 , Reply# 6   7/21/2009 at 18:58 (5,390 days old) by autowasherfreak ()   |   | |
Strange, the squeal lasted only for one load and quit. Nice and quiet. |
Post# 366062 , Reply# 7   7/21/2009 at 21:50 (5,390 days old) by jons1077 (Vancouver, Washington, USA)   |   | |
