Thread Number: 2360
Frigidaire WCIR-60 |
Post# 70099   6/13/2005 at 17:19 (6,890 days old) by variflexpghpa (Pittsburgh, PA)   |   | |
Heres a few pix of my recent find. Other then a case of a bit of hose rot it runs fine |
Post# 70100 , Reply# 1   6/13/2005 at 17:23 (6,890 days old) by variflexpghpa (Pittsburgh, PA)   |   | |
Heres a close up of the timer |
Post# 70101 , Reply# 2   6/13/2005 at 17:27 (6,890 days old) by variflexpghpa (Pittsburgh, PA)   |   | |
Ok heres where the expert help is needed. Hiding under the agitator cap is a philips-headed bolt. I believe I need to remove the bolt in order to replace the pulsator ring. I didnt want to muscle it out without some guidance. Any help is definitely appreciated. |
Post# 70102 , Reply# 3   6/13/2005 at 17:29 (6,890 days old) by variflexpghpa (Pittsburgh, PA)   |   | |
Heres the replacement pulsator all ready to be installed.. .when the bolt can be removed |
Post# 70124 , Reply# 4   6/13/2005 at 18:38 (6,890 days old) by rickr (.)   |   | |
Post# 70186 , Reply# 7   6/13/2005 at 22:36 (6,890 days old) by golittlesport (California)   |   | |
Post# 70244 , Reply# 10   6/14/2005 at 08:43 (6,889 days old) by Unimatic1140 (Minneapolis)   |   | |
Post# 70915 , Reply# 14   6/20/2005 at 07:37 (6,883 days old) by jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Variflexpghpa, it is important that you properly ground the washer. What you can do is either install a three prong grounded cord on the washer or take a piece of wire and attach one end to any metal screw on the washer cabinet, take the other end and clamp it to a copper cold water pipe. The machine should not be used without proper grounding.
Post# 71070 , Reply# 15   6/21/2005 at 17:21 (6,882 days old) by Stainfighter (Columbia, SC)   |   | |
