Thread Number: 23697
Frigidaire 'Filtrator?' |
Post# 368904 , Reply# 1   8/1/2009 at 14:58 (5,353 days old) by appnut (TX)   |   | |
Post# 368986 , Reply# 2   8/1/2009 at 21:42 (5,353 days old) by bugsyjones ()   |   | |
It's just pictures. Does it 'filter' the hot air and vent it back into the room out of the front? Does it have an external exhaust? HOW DOES IT WORK?! ~Tim |
Post# 368987 , Reply# 3   8/1/2009 at 21:48 (5,353 days old) by appnut (TX)   |   | |
The Filtrator heats with calrod's in the upper left portion of the dryer, this in turn heats the dryer tub. A fan driven off the drive motor draws air thru the tub down and across the filtrator tubes, the condensed water in the tubes falls to a collection tray below that is emptied at the end of the days use. |
Post# 368988 , Reply# 4   8/1/2009 at 21:49 (5,353 days old) by appnut (TX)   |   | |
Post# 368993 , Reply# 7   8/1/2009 at 22:14 (5,353 days old) by joelippard (Hickory)   |   | |
Post# 368994 , Reply# 8   8/1/2009 at 22:20 (5,353 days old) by joelippard (Hickory)   |   | |
Post# 369060 , Reply# 10   8/2/2009 at 11:55 (5,352 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
Post# 369166 , Reply# 11   8/2/2009 at 23:19 (5,352 days old) by bugsyjones ()   |   | |
I would... ...if.... ...you'll give me your 57 Control Tower set. ~Tim |
Post# 369214 , Reply# 12   8/3/2009 at 08:25 (5,352 days old) by everythingold (Grand Rapids, Michigan)   |   | |
