Thread Number: 24041
Old Maytag Wringer washer |
Post# 373859   8/22/2009 at 16:08 (5,353 days old) by retromaytag ()   |   | |
Hi, What can you tell me about this one? The seller is asking $60, but they don't really know much about it. Any ideas on the year, model etc? Thanks fellows! |
Post# 373869 , Reply# 1   8/22/2009 at 16:53 (5,353 days old) by redcarpetdrew (Fairfield, CA)   |   | |
That looks like a E2LP Master washer. The serial number stamped into the metal on the backside will tell the age. I have a 1957 E2LP washer that was in storage for a decade or two in a barn and it fired up first shot with no issues. I even shot some video of it washing. If it's functional I'd say GO FOR IT! It looks so clean, I'd go for it anyway for only $60! You'll have to find the gooseneck that screws onto the end of the drain hose if it isn't there somewhere. RCD CLICK HERE TO GO TO redcarpetdrew's LINK |
Post# 373881 , Reply# 2   8/22/2009 at 18:04 (5,353 days old) by bradross (New Westminster, BC., Canada)   |   | |
Post# 373909 , Reply# 3   8/22/2009 at 20:29 (5,353 days old) by norgeway (mocksville n c )   |   | |
I have seen these on craigs list for 150 00, the best washing wringer you will use, I think the square tub has something to do with it, but it washes a lot better than a Maytag automatic. |
Post# 373931 , Reply# 4   8/22/2009 at 22:33 (5,353 days old) by volvoguy87 (Cincinnati, OH)   |   | |
That actually looks like an E2LPS, the one I would love to find! It has a pump and a safety system. The safety system has usually deteriorated by now and can be bypassed by installing a 1/2 inch wide machine bolt to effectively turn it into an E2LP, but more on that after you get it. This looks like the 1968-1983 version. It is a very good price, so don't let it sit there, go and get it! Dave |
Post# 373942 , Reply# 6   8/22/2009 at 23:15 (5,353 days old) by qsd-dan (West)   |   | |
That is the ultimate score for $60! "I guess it comes on when you plug it in? And it starts cycling when you pull the knob on the side? The lever activates the pump?" That's pretty much it. Not much to a wringer :) "I couldn't get the wringer to work though. How does it operate? " The lever to the right of the wringer head operates the wringer and its direction. Not sure how it works on an E2LPS (I have only played with RCD's E2LP), but pushing the lever forward should operate the wringer in one direction, pulling back should operate it in the opposite direction. We need pics!!! |
Post# 373978 , Reply# 7   8/23/2009 at 07:53 (5,353 days old) by polkanut (Wausau, WI )   |   | |
Being an E2LPS means there was a rubber bulb attached to a tube that causes the wringers to operate with air pressure when stepped on, a true PITA. Like Dave mentioned above, you can install a 1/2 bolt in opening where the tube would connect. This will override the need for the bulb and tube. On the left side of the wringer head you'll find the directional lever. Moving it away from you will let you feed items forward through the wringer, move the lever toward you and it will reverse the direction of the rollers. Finding a NOS bulb and tube is getting more & more difficult. Don't be alarmed if it leaks a little oil, this is somewhat normal, though annoying. I sold a 1981 E2LS (gravity drain) that was altered like this, and it was a fantastic machine, kinda wish I would've kept it now.
