Thread Number: 24151
Washing Machine Test Results |
Post# 375373   8/28/2009 at 13:37 (5,326 days old) by logixx (Germany)   |   | |
So here are the test results from this years test of washing machines. I posted what the consumer magazine had to say about each washer, the overall score and the average retail price. Some notes: - tested cycles were Cottons 40*C, Easy Care, Cottons Quick Wash (including wash, rinse and spinning result) and the Wool cycle. Furthermore, the duration of the Quick cycle. - the endurance was tested by running three models of each machine through 1840 cycles - the easy-of-use test included: instruction manual, detergent drawer, fascia, (un-) loading of laundry, maintenance, fluffiness of laundry after the spin cycle and accuracy of the count down timer - the environmental friendliness test included: water and energy consumption on the three above named cycles, energy consumption during stand-by operation and when switched off and noise during washing and spinning - the leakage protection system was also tested ("safe" or not) Achivable grades are: Very Good, Good, Satisfactory, Poor, Very Poor Miele W1743 WPS EcoLine Expensive Winner: Best function and highest user-friendliness. Washes and spins Good and is one of the better machines at rinsing. Very reliable and safe washer for 6 kg of laundry. Frugal with water and energy, only the Easy Care cycle uses a little more. Easy to use. Quiet. -> Good (1.8) / 1020 AEG/Electrolux Φko Plus 1400 Good all around: Washes Good, the best on the quick cycle. Spins Good to Very Good but not on the quick cycle. Weaknesses at rinsing, especially on the 40*C Cottons cycle. Frugal with water and energy; slightly higher energy consumption only on the Easy Care cycle. Very reliable, safe and easy to use washer for 7 kg of laundry. Quiet. -> Good (2.0) / 735 Siemens WM14E140 No count down timer: Washes Good but Poor rinsing at Cottons 40*C, otherwise Good to Very Good. Spins Good except for the quick cycle, which also takes long. Easy to use but no delay start or count down timer. Relatively high energy consumption on the quick cycle. Very safe, reliable and quiet machine for 6 kg of laundry. -> Good (2.0) / 560 Bosch WAE2834P A little slow: Washes Good but weaknesses at rinsing, especially on Cottons 40*C. Spins Good except for the quick cycle, which also takes long and uses relatively much energy. All in all easy to use but door is a little hard to close. Very safe, reliable and quiet machine for 6 kg of laundry. -> Good (2.1) / 620 Samsung WF 8724 Frugal: Only the quick cycle washes Good, otherwise Satisfactory. Weaknesses at rinsing, especially on Cottons 40*C. Spins Good to Very Good but not on the quick cycle. Easy to use but count down timer inaccurate. Very safe and reliable washer for 7 kg of laundry. Frugal with water and energy. -> Good (2.2) / 630 Blomberg WAF 7442 SL Good value: Washes Good but on Easy Care only Satisfactory. Spins Good but not on Cottons 40*C, which also has Poor rinsing. Easy to use. Laundry isn't fluffy after the spin cycle. Safe, very reliable washer for 7 kg of laundry. Highest score for environmental friendliness, frugal with water and energy. Good -> (2.3) / 525 Privileg Dymanic 78614 Easy to use: Washes Good, spins Good (except for Easy Care) but rinses only Satisfactory. Electronics prone to failure. Frugal with water and energy but slightly higher water consumption on Easy Care. Spin cycle is pretty loud. Very safe, easy to use washer for 6 kg. -> Good (2.5) / 670 Whirlpool AWO 6246 Loud and not very safe: Only the quick cycle washes Good, otherwise Satisfactory. One of the better washers at rinsing and spinning. Noisy. Very reliable and affordable washer for 5 kg. Poor leakage protection and relatively high water and energy consumption. -> Satisfactory (2.6) / 465 Gorenje WA 75145 Frugal but a little prone to failure: Only Easy Care washes Good, otherwise Satisfactory. One of the best washers at spinning the worst at rinsing. Slightly failure-prone washer for 7 kg. Poor leakage protection. Very frugal with water and energy but highest stand-by energy consumption. -> Satisfactory (2.9) / 980 Bauknecht WA Pure XL 34 TDi Leaking: Did not pass the endurance test: the rubber door boot tore so that water leaked. Otherwise easy to use washer for 7 kg with all around Good washing results. One of the best ones at spinning but one of the worst at rinsing. -> Poor (5.0) / 530 LG F1403TD Broken: This washer of 8 kg capacity failed the endurance test due to a faulty heating element and torn-off drum vanes. Otherwise washes Good on Easy Care and the quick cycle. Best washer at spinning but Very Poor at rinsing on 40*C Cottons. Easy to use but noisy and slow. -> Very Poor (5.0) / 705 Alex |
Post# 375383 , Reply# 1   8/28/2009 at 16:00 (5,326 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
Thanks for sharing!! I noticed Miele had already a press release to announce the news that they came best out of the test. I wonder why Siemens is ranked third, both AEG score 2.0 but the Siemens is much cheaper. I guess it's a good alternative to the Miele. I would love to try one for a while. Typical to see Bauknecht in the lower regions again. They can't pull their act together apparently. Louis |
Post# 375384 , Reply# 2   8/28/2009 at 16:02 (5,326 days old) by ronhic (Canberra, Australia)   |   | |
Post# 375389 , Reply# 3   8/28/2009 at 16:17 (5,326 days old) by logixx (Germany)   |   | |
Post# 375571 , Reply# 4   8/29/2009 at 14:11 (5,325 days old) by rolls_rapide (.)   |   | |
I imagine it is because the AEG has a larger capacity than the Siemens, thus making it more environmentally friendly - kg for kg. |
Post# 375579 , Reply# 5   8/29/2009 at 15:34 (5,325 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
