Thread Number: 24175
Many Problems with LG Dishwasher |
Post# 375605   8/29/2009 at 19:20 (5,352 days old) by wetguymd (Maryland)   |   | |
I bought an LG Steam Tall Tub (model LDF7932ST) from Homo Depot and have had nothing but trouble. First, when they installed it they didn't do it correctly and the mounting screws fell out and it was hanging out of the cabniet. After having them come back and redo it the same thing happened again within 2 days. The last time the guy showed me how they have damaged the sides of the cabniets due to not using the correct screws. I replaced a wonderful old Kitchenaid that had electrical problems. I need my butt kicked for not having this repaired! Thankfully I still have it. It washed wonderfully and this new one, while very quite just doesn't get the dishes as clean and since it doesn't have the hard food disposal you basically have to wash the dishes before. Tonight I opened the door to add a dish after I had turned it on and found that it doesn't stop when you open the door! I had water spraying all over the place. Does anyone know if this is how they are made or is there a major problem? I can tell you if I have to call them to come back it won't be to repair it but to remove it out of my house. I can't imagine this is how its suppose to be. |
Post# 375609 , Reply# 1   8/29/2009 at 19:27 (5,352 days old) by norfolksouthern ()   |   | |
Congratulations, wetguymd. You are now a born again appliance collector. NorfolkSouthern |
Post# 375613 , Reply# 2   8/29/2009 at 19:36 (5,352 days old) by frigilux (The Minnesota Prairie)   |   | |
I have a steam tall-tub LG, model 9810. Mine has a hard food disposal, and really, so should yours. I wasn't aware that any LG models had filters you have to clean manually. I never pre-rinse anything; in fact, I barely scrape the dishes. There's never any residue left on dishes. It's the best-cleaning dishwasher I've ever owned. Mine also stops as soon as you pull the door open. Something is wrong with your machine, and you should have them replace it, especially since it's been damaged through faulty installation. Consumer Reports has remarked that LG dishwashers have been prone to repairs. I've had mine for a year, use it heavily, and so far it's been reliable. I have soft water and use Cascade Action Pacs and Cascade Complete liquid gel. |
Post# 375614 , Reply# 3   8/29/2009 at 19:39 (5,352 days old) by frigilux (The Minnesota Prairie)   |   | |
Post# 375620 , Reply# 4   8/29/2009 at 19:49 (5,352 days old) by peteski50 (New York)   |   | |
One bad experience that I had being a LG owner is the combo washer dryer I had - nothing but heart aches - and I dumped that piece of trash 2 years ago and am now happy for it. Their service is the worst ever. Stay away from LG. If you want the full story read LG service nightmare under google. Good Luck Peter |
Post# 375622 , Reply# 5   8/29/2009 at 19:59 (5,352 days old) by frigilux (The Minnesota Prairie)   |   | |
I bought my dishwasher from a local LG dealer that does all their own servicing, which is the only reason I considered purchasing an LG product. If you're going to buy from Home Depot, who don't do their own repairs, I'd look for a different brand. Like Pete, I've read about many instances of people having bad experiences with LG's own service department.
Post# 375628 , Reply# 6   8/29/2009 at 20:27 (5,352 days old) by laundromat (Hilo, Hawaii)   |   | |
If you don't have good water presure,your problem may stem from that.When it's low,the dishwasher will try to work but the water is not circulating properly at the correct volocity. I have great presure here and can tell when there's plenty of water in my dishwasher because I can go in front of it and hear the water circulating and splashing around.
Post# 375680 , Reply# 7   8/29/2009 at 23:18 (5,352 days old) by wetguymd (Maryland)   |   | |
While it does have a "hard food disposal" its not the same as the Kitchenaid had. This will grind up small stuff but they recommend not putting alot of food particles in there. With the other one I could put a full plate, not that I ever did, of food in there and it would take care of everything. The guy that did that last re-install is also in service and said that the power of the motor is no where as strong as the old Kitchenaids. I do have very good water pressure and also have a water softner and use the Cascade Action Pacs. I know its moves water around and saw that first hand when I opend the door and it didn't stop spraying. |
Post# 375699 , Reply# 8   8/30/2009 at 00:00 (5,352 days old) by frigilux (The Minnesota Prairie)   |   | |
Your service man is right, these machines have very small motors compared to your KitchenAid. Since the tub only fills with about 1 gallon of water and sprays one rack at a time, a smaller motor can be used. This allows the machine to be more quiet and it uses less electricity. I've had KitchenAids, and they are great dishwashers, but my LG (using the steam option and the soak cycle) cleans pots/pans better. I have no explanation for why your machine isn't cleaning well, as you have soft water and are using a top-notch detergent. Mine cleans like a champ! You'll probably be happier with a different brand. No sense in keeping a dishwasher that you're not happy with. |
Post# 375715 , Reply# 9   8/30/2009 at 04:50 (5,351 days old) by spankomatic (Ukiah,CA)   |   | |
Post# 376306 , Reply# 11   9/1/2009 at 22:55 (5,349 days old) by frigilux (The Minnesota Prairie)   |   | |
Andrew---I believe we bought our LG 9810's at about the same time, didn't we? I get a little nervous that yours has already required repairs! Consumer Reports didn't have enough responses to rate its reliability, but said that based on the limited information they had, the machines were among the least reliable. (On the other hand, LG washing machines were listed as being very reliable.) When washing a load of pots/pans, I use more detergent than the manual recommends. I fill the main wash compartment full with Cascade Complete Gel, then squirt an equal amount in the bottom of the tub for the pre-wash. For other loads, I use 1 Cascade Action Pac or Cascade Complete 3-in-1 Pac. So far, I haven't noticed any problems with a calcified filter, but I also have very soft water. I've only chosen the Extra Rinse option once, the very first time I used the machine. I've never really noticed a need for it. I love the steam option. I use it with really grungy dish loads and always with pots/pans loads. I also use the 160-degree rinse more than I ever did with my Frigidaire or Maytag dishwashers. The LG heats the water very quickly, so it doesn't add much time to the cycle. In fact, I never purge cold water from the line before starting a cycle with the LG. Always had to with my other machines or it seemed to add a noticeable amount of heating time to the main wash. My LG endures very heavy use. I almost always leave the door open overnight so the interior dries. I don't like to leave it closed up and warm/damp inside. I close it when I get up in the morning. The blue interior lights (LEDs) make for a nice kitchen nightlight. I don't usually notice when it switches from washing the bottom rack to the top rack. When I had a TOL 2005 Frigidaire, the switch was very obvious. The LG is so quiet I forget it's running, even when I'm working in the kitchen. Knock on wood, my 9810 soldiers on without incident! |
Post# 376409 , Reply# 13   9/2/2009 at 16:22 (5,348 days old) by frigilux (The Minnesota Prairie)   |   | |
