Thread Number: 24212
I am having a problem with my Hootag! |
Post# 376067 , Reply# 1   12/31/2069 at 18:00 (19,837 days old) by electron1100 (England)   |   | |
it depends how far you are prepared to delve inside the machine. I personaly would check the water level switch tube is not blocked with cacked up detergents Find the water level switch and follow the air tube down to where it is connected to the drum (on older machines it connects to a small plastic vessel), i know on older Hoover machines if this becomes blocked or partially blocked the machine wont spin,or wash there are various symptons I presume it has a seperate pump for the jet rinse, make sure this is not blocked You could try putting the machine on a boil wash a few times as this would help remove detergent deposits.........i have never seen the insides of one these machines so i cannot really offer any more suggestions. Gary |
Post# 376204 , Reply# 2   9/1/2009 at 15:53 (5,348 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
Post# 376884 , Reply# 3   9/4/2009 at 18:20 (5,345 days old) by paulinroyton (B)   |   | |
Hi Guys. There is a Servis top loader on ebay, model M602TL. The person selling it says they have only washed with it about 6 times, and now it wont work. Paul |
