Thread Number: 24408
Hotpoint Liberator (updated) plus other newly saved machines |
Post# 378848 , Reply# 1   9/14/2009 at 13:00 (5,336 days old) by matchboxpaul (U.K)   |   | |
the worn bearings... |
Post# 378849 , Reply# 2   9/14/2009 at 13:01 (5,336 days old) by matchboxpaul (U.K)   |   | |
from the front... |
Post# 378850 , Reply# 3   9/14/2009 at 13:02 (5,336 days old) by matchboxpaul (U.K)   |   | |
drum shaft... |
Post# 378851 , Reply# 4   9/14/2009 at 13:03 (5,336 days old) by matchboxpaul (U.K)   |   | |
perished seal and lots of rusty bleeding going on... |
Post# 378853 , Reply# 5   9/14/2009 at 13:03 (5,336 days old) by matchboxpaul (U.K)   |   | |
under the rubber seal... |
Post# 378854 , Reply# 6   9/14/2009 at 13:04 (5,336 days old) by matchboxpaul (U.K)   |   | |
back over the other side, ready to start knocking the old bearings out... |
Post# 378856 , Reply# 7   9/14/2009 at 13:06 (5,336 days old) by matchboxpaul (U.K)   |   | |
now for the difficult bit. Involved tearing out the top outer bearing, befor the inner bearing could be knocked out. 33 years meant that they were a b1tch to remove... |
Post# 378857 , Reply# 8   9/14/2009 at 13:07 (5,336 days old) by matchboxpaul (U.K)   |   | |
outer bearing removed meant that the inner bearing (shown here) could be knocked out... |
Post# 378859 , Reply# 9   9/14/2009 at 13:09 (5,336 days old) by matchboxpaul (U.K)   |   | |
manky! hands were heavily stained with rust, if you touched the old bearings set. I kept the old bearing from the microprofile, but this set was way beyond salvage... |
Post# 378861 , Reply# 10   9/14/2009 at 13:10 (5,336 days old) by matchboxpaul (U.K)   |   | |
top of the machine... |
Post# 378863 , Reply# 11   9/14/2009 at 13:11 (5,336 days old) by matchboxpaul (U.K)   |   | |
new outer bearing in... |
Post# 378865 , Reply# 12   9/14/2009 at 13:12 (5,336 days old) by matchboxpaul (U.K)   |   | |
new inner bearing in.... |
Post# 378866 , Reply# 13   9/14/2009 at 13:12 (5,336 days old) by matchboxpaul (U.K)   |   | |
new bearing seal... |
Post# 378867 , Reply# 14   9/14/2009 at 13:13 (5,336 days old) by matchboxpaul (U.K)   |   | |
putting back together again... |
Post# 378868 , Reply# 15   9/14/2009 at 13:14 (5,336 days old) by matchboxpaul (U.K)   |   | |
Rob, with the finished product... |
Post# 378870 , Reply# 16   9/14/2009 at 13:15 (5,336 days old) by matchboxpaul (U.K)   |   | |
again... |
Post# 378872 , Reply# 17   9/14/2009 at 13:19 (5,336 days old) by electron1100 (England)   |   | |
Brilliant Paul, the satisfaction of replacing knackerd bearings cannot be described, i love studying the old ones....dip them in white spirit and have a good look at them . But fitting the new ones is even better, peace of mind follows.........and when your doing it to a classic machine its even better! Lovely fots Paul Thanks Ps the ice box works :-) |
Post# 378873 , Reply# 18   9/14/2009 at 13:21 (5,336 days old) by matchboxpaul (U.K)   |   | |
first wash vid and quite a heavy load, comprised of jeans... CLICK HERE TO GO TO matchboxpaul's LINK |
Post# 378874 , Reply# 19   9/14/2009 at 13:23 (5,336 days old) by matchboxpaul (U.K)   |   | |
Hi Gary. All thanks to Mathew and Rob for the hard work with it. Great that the ice box works - give her a clean and see how she comes up. Will e-mail you piccies of your new machine later tonight! cheers for commenting. paul |
Post# 378875 , Reply# 20   9/14/2009 at 13:23 (5,336 days old) by matchboxpaul (U.K)   |   | |
onto rinse... |
Post# 378876 , Reply# 21   9/14/2009 at 13:25 (5,336 days old) by matchboxpaul (U.K)   |   | |
a second vid, this time of the rinse, with water taken in, some washing followed by drain... CLICK HERE TO GO TO matchboxpaul's LINK |
Post# 378881 , Reply# 22   9/14/2009 at 13:31 (5,336 days old) by matchboxpaul (U.K)   |   | |
here is the dial - rather mucky and very difficult to clean. luckily, i have managed to source most of the parts needed to make a new one. Wont be replaced though until its mechanically required... |
Post# 378882 , Reply# 23   9/14/2009 at 13:32 (5,336 days old) by matchboxpaul (U.K)   |   | |
the famous name... |
Post# 378883 , Reply# 24   9/14/2009 at 13:33 (5,336 days old) by matchboxpaul (U.K)   |   | |
the options... |
Post# 378884 , Reply# 25   9/14/2009 at 13:34 (5,336 days old) by matchboxpaul (U.K)   |   | |
the programmes.... |
Post# 378885 , Reply# 26   9/14/2009 at 13:35 (5,336 days old) by matchboxpaul (U.K)   |   | |
the ratings plate.... |
Post# 378887 , Reply# 27   9/14/2009 at 13:40 (5,336 days old) by matchboxpaul (U.K)   |   | |
compare and contrast this OLD vid, which was taken before the repair work was done. in fact it was taken a day after we collected the machine.... CLICK HERE TO GO TO matchboxpaul's LINK |
Post# 378889 , Reply# 28   9/14/2009 at 13:47 (5,336 days old) by matchboxpaul (U.K)   |   | |
....with this vid of the finished article, spinning its load of jeans. Could almost be a different machine... CLICK HERE TO GO TO matchboxpaul's LINK |
Post# 378890 , Reply# 29   9/14/2009 at 13:50 (5,336 days old) by matchboxpaul (U.K)   |   | |
here she lies dormant, waiting for the day she can be more permanently placed in a home... |
Post# 378898 , Reply# 31   9/14/2009 at 13:55 (5,336 days old) by matchboxpaul (U.K)   |   | |
making it a perfect match for out 17221 compact dryer, which was made in exactly the same month of 1983... |
Post# 378899 , Reply# 32   9/14/2009 at 13:55 (5,336 days old) by matchboxpaul (U.K)   |   | |
tomorrow evening! Cheers Paul |
Post# 379461 , Reply# 33   9/16/2009 at 13:44 (5,334 days old) by hotpoint95622 (Powys)   |   | |
Post# 379475 , Reply# 34   9/16/2009 at 14:45 (5,334 days old) by deeprinser ()   |   | |
Hi. You have two of my all time favourites- Liberator- Purple . Ahhh-- lovely! Timeline Top loader. Im now off to watch your YT video for a "fix" . Regards. Louis. |
Post# 379646 , Reply# 36   9/17/2009 at 11:09 (5,333 days old) by matchboxpaul (U.K)   |   | |
some of you will have this piccy before, of the elctron that i bought for scrap from an understanding repair shop.... |
Post# 379647 , Reply# 37   9/17/2009 at 11:10 (5,333 days old) by matchboxpaul (U.K)   |   | |
well it was taken across to mikes bank holiday weekend do too! here it is upright and pre cleaning... |
Post# 379648 , Reply# 38   9/17/2009 at 11:11 (5,333 days old) by matchboxpaul (U.K)   |   | |
a bit closer, revealing (hopefully) the thin film of grease and grime that was on the machine... |
Post# 379650 , Reply# 39   9/17/2009 at 11:12 (5,333 days old) by matchboxpaul (U.K)   |   | |
ta da! |
Post# 379651 , Reply# 40   9/17/2009 at 11:14 (5,333 days old) by matchboxpaul (U.K)   |   | |
and here are the internals. not too mucky, but the cleaning will be left till its repair work is done.... |
Post# 379655 , Reply# 44   9/17/2009 at 11:24 (5,333 days old) by matchboxpaul (U.K)   |   | |
and a small amount of rust just under the bottom of the door seal. drum bearings are solid as a rock... |
Post# 379656 , Reply# 45   9/17/2009 at 11:26 (5,333 days old) by matchboxpaul (U.K)   |   | |
mathew attaches the water pipes to the back of the machine. he also reattached a new electric cable to the machine, as the old one had been cut right at the bodyshell of the machine.... |
Post# 379657 , Reply# 46   9/17/2009 at 11:28 (5,333 days old) by matchboxpaul (U.K)   |   | |
a short burst of special treatments, before the machine reached creaseguard. in fact it surprised us all - it hardly did anything before hitting creaseguard... |
Post# 379658 , Reply# 47   9/17/2009 at 11:29 (5,333 days old) by matchboxpaul (U.K)   |   | |
programme guide and creaseguard light... |
Post# 379659 , Reply# 48   9/17/2009 at 11:30 (5,333 days old) by matchboxpaul (U.K)   |   | |
programmer sat at creaseguard point on special treatments programme... |
Post# 379661 , Reply# 49   9/17/2009 at 11:32 (5,333 days old) by mattywashboy (Perth, Western Australia)   |   | |
Awesome Electron Paul! My grandmother bought one of these machines second hand when her Servis SupaTwin died and was sent into the shed for me to play with. It was a slightly different colour, more a lighter grey colour. It also had a delay start dial, slightly smaller just next to the programmer. We never used the powder drawer button. The drawer was just as easily opened by pulling on the bottom (grandma had long nails so was easy enough for her). Oh the memories. It never had a chrome strip around the door, this was lost by its previous owner so its weird seeing one with it attached, the pic with it removed is much more familiar to me. Hope this one lasts a while :-) i think it was the timer that went on grans in the end, coz we had to move it along manually to each stage :-) |
Post# 379662 , Reply# 50   9/17/2009 at 11:40 (5,333 days old) by matchboxpaul (U.K)   |   | |
here is the video link to the brief special treatments programme. remember this machine was being water tested and electrically tested, so we didnt force it to do much... CLICK HERE TO GO TO matchboxpaul's LINK |
Post# 379667 , Reply# 52   9/17/2009 at 11:48 (5,333 days old) by matchboxpaul (U.K)   |   | |
with the white streak.... |
Post# 379669 , Reply# 53   9/17/2009 at 11:50 (5,333 days old) by matchboxpaul (U.K)   |   | |
revealing a birthmonth of November 1983... |
Post# 379670 , Reply# 54   9/17/2009 at 11:51 (5,333 days old) by matchboxpaul (U.K)   |   | |
preparing for spin... |
Post# 379675 , Reply# 56   9/17/2009 at 12:12 (5,333 days old) by matchboxpaul (U.K)   |   | |
cycle finished... |
Post# 379676 , Reply# 57   9/17/2009 at 12:13 (5,333 days old) by matchboxpaul (U.K)   |   | |
here be the drum - still in good condition, for the amount of work it will have done over its general working life... |
Post# 379680 , Reply# 59   9/17/2009 at 12:44 (5,333 days old) by hotpoint95622 (Powys)   |   | |
Post# 379681 , Reply# 60   9/17/2009 at 12:59 (5,333 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
There boys....machines cleaned up a treat, that Zanni cradle would fetch a bit as scrap its that solid & heavy....a special "Thank You" to John for having the machines renovated on his patch...all good fun and learning!!! Oh, dont worry, that old Hoovers well out the way, flogged it for another turquoise keymatic door boot!!!...Lol...actually it is...I moved it into storage so I could make way for more 18 silver series goodies!!!now wheres that purple paint Morag!!! |
Post# 379691 , Reply# 65   9/17/2009 at 14:08 (5,333 days old) by electron1100 (England)   |   | |
Well Paul excellent job on the Hoover 800, a very smart looking piece of Hoover History..........its very nice......now if Mike will release it from his wharehouse you will find it a peice of pi.s to service up. The same for the Hotpoints very smart machines. Now where the bloody hell is ROB ?????? is he lost inside a Hotpoint time line???????? have you packed him away in a storage unit by accident? or has he moved in to a storage unit and refusing to leave as he cant have all favourite machines about him Thanks Paul for posting these excellent pictures and videos Gary |
Post# 379705 , Reply# 66   9/17/2009 at 15:53 (5,333 days old) by aquarius1984 (Planet earth)   |   | |
Im here along with a voice like Lieutenant Pigeon's Wish I was living at storage LOL. Would have bene around more had I not got a stinking cold. Done myself worse by going into work instead of staying off. Over the worst of it now but still feel rough and looking rough. 1 day until the weekend thank god, weekend will be spent dust busting this place. Something in this house is making me cough. Will be getting that Duvet washed along with the curtains, mats and maybe even a good old carpet vaxing. Cue the Hoover Turbomaster........ Just so glad no machines require immediate attention. I hope I aint spoken too soon though, |
Post# 379856 , Reply# 70   9/18/2009 at 12:10 (5,332 days old) by hotpoint95622 (Powys)   |   | |
