Thread Number: 2471
More Hoover Twin Tub Woes/Questions |
Post# 71518   6/26/2005 at 19:38 (6,876 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
My TT's extractor basket is slightly out of alignment, and methinks a slack belt is to blame. One can see in my snaps of the basket how it is slighly off center when empty and becomes more so when doing large loads (well large for the twinne, a few towels or two king sized bed sheets). Anywho long story short is one correct in assuming the only way to replace the spin belt is to remove one or both of the bolts/nuts holding the spinner to the t-brace? Next problem: Had the TT on it's side dealing with the slack belt problem and noticed the rubber gasket which meets the bottom of the spin basket and is round the "spindle" which leads down to the base/pulley is developing a crack. As of now the crack is roughly 11 o'clock to 3 o'clock, but am very worried it will go all the way round. Applied a dab of "Seal All", but have a hunch it really will not work (what can one expect of 20-30 year old rubber gaskets). Are these gaskets easily replaced/found? Is this problem as bad as it seems/likely to get worse? Only wish to know before spend funds on a new pump, belts and hoses. Do not wish to do all that work only to have a washer that will need to be coddled or is in it's declining years. Lesson learned about buying vintage washers sight unseen; Not a good idea unless one either knows who one is dealing with or willing to pays their money and take their chances. Had I known this washer, despite being "never used" was going to become a can of worms, would have perhaps passed. Thanks all, Launderess |
Post# 71673 , Reply# 2   6/28/2005 at 04:58 (6,874 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
The dab of "Seal All" when dried acutally seemed to to a bit of good in holding the "crack" together. Now that I know not to worry so much am not going to fool around with it further. Poured a cup or so of water into the spin basket, and checked the newspaper under the washer(from the day before's laundry), and while the pump still leaks, the area under the spin basket was dry. Will take this to mean no leak at present, so will leave well enough alone. When empty the spin basket is only slighly off centre, so can assume the few loads spun out previously were causing the tub to go unbalanced. It really has been to hot to bother with all the palaver that twin tub laundering entails. Did try and so some of the bed linens the other day, but really can fit only one king sized sheet in the wash tub at one time. Seeing as I had several, and was in no mood to live "1900 House", put the rest into the washer. Must find a longer drain hose, as the Hoover one is too short. Am eyeing those sold over in UK, that look like the later US Hoover drain hoses (that came from the back instead of top of the washer). Problem with using modern drain hoses is of course finding one that fits the pump. Am using an old washing machine hose (left over from our Malber)that "quick connects" at the sink, but is long enough to reach th washer. Please don't worry about the pump and any other bits you may have for me. Continue on with your work/house and let me know when the time is right. Thanks for everything, Launderess |
Post# 71713 , Reply# 4   6/28/2005 at 16:47 (6,874 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
It never ends, does it? Thanks for the news about the pump! The current pump's rubber ring around the top part was cracked but did not leak. You can see this in my snaps of the washer. Tightly wrapping plumber's tape around the seal managed to make it tight enough to lock out air and allow the pump to work. Let us hope your ideas work regarding replacements! Keeping my fingers and toes crossed. Actually took some spare castors had lying around from another washer to use on the twinnie. So far so good and was kind of glad to switch, as the hard rubber Hoover castors were destroying my floors! Other parts? Was going to order spare pump belts (red spot) and others to replace/have on hand as extras. Since Hoover has stopped making these units in the UK as well, it does seem prudent to lay in supplies while dealers there have them on their stocklists. If only we had known this back in the 1980's when Hoover discontinued TTs in the United States, could have snapped up lots of parts that probably went into the rubbish. Still looking for a drain hose, and have seen pictures of the longer hose used on the later American Hoovermatic's and their cousins sold in the UK, not sure about the length though, and cannot find measurements anywhere. Oh well, enough of my rambling, need to soder a loose connection on a transformer. Thanks again for all your assistance and hope all goes well with your car. Launderess |
Post# 71725 , Reply# 6   6/28/2005 at 18:27 (6,874 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Don't want to go too deep on finding an exact hose as we all know this particular pump is not long for this world,and would need a hose that will also fit the new pump (when I get one). For now the leaking while a major pain, has me more worried about it causing damage to the belts or other parts of the washer. As for protecting my floors/mopping up the mess, just ordered a job lot of "wee-wee" pads (those huge absorbent pads one puts beneath a puppy while training, or are used on the beds of those with bladder/bowel problems). These pads will hold almost a Hoover damn worth of water (see how nicely I kept this on topic?), and keep the floor beneath dry. It is as much as I can manage for now, so it will have to do. Find the biggest use for the twinne so far in soaking dirty shirts and linens before laundering. Something one cannot do in a front loader. On the plus side since one is not actually "washing" can put more items than usual in the wash tub and not have them come out in a tangle. Tub soaking is also wonderful because all the gunk/soil falls to the bottm of the tub; one simply lifts items out of the water leaving the muck behind to be pumped out. Keep those suggestions coming guys! |
