Thread Number: 24925
My Hobart U|M-4 from Philadelphia has ARRIVED! |
Post# 384921 , Reply# 1   10/13/2009 at 12:01 (5,302 days old) by bobbins (Victoria, BC, Canada)   |   | |
More pictures.. Bob |
Post# 384922 , Reply# 2   10/13/2009 at 12:02 (5,302 days old) by bobbins (Victoria, BC, Canada)   |   | |
Post# 384923 , Reply# 3   10/13/2009 at 12:02 (5,302 days old) by bobbins (Victoria, BC, Canada)   |   | |
Again more pictures.. Bob |
Post# 384924 , Reply# 4   10/13/2009 at 12:03 (5,302 days old) by bobbins (Victoria, BC, Canada)   |   | |
Another one.. Bob |
Post# 384925 , Reply# 5   10/13/2009 at 12:04 (5,302 days old) by bobbins (Victoria, BC, Canada)   |   | |
Post# 384928 , Reply# 6   10/13/2009 at 12:12 (5,302 days old) by turquoisedude (.)   |   | |
Post# 384934 , Reply# 7   10/13/2009 at 12:37 (5,302 days old) by rollermatic (cincinnati)   |   | |
Post# 384940 , Reply# 8   10/13/2009 at 13:01 (5,302 days old) by toggleswitch2 ()   |   | |
WOW GREAT! CONGRATS! |
Post# 384943 , Reply# 9   10/13/2009 at 13:06 (5,302 days old) by yogitunes (New Jersey)   |   | |
Post# 384965 , Reply# 10   10/13/2009 at 14:36 (5,302 days old) by jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 384969 , Reply# 11   10/13/2009 at 14:53 (5,302 days old) by bobbins (Victoria, BC, Canada)   |   | |
I will investigate...I was thinking the same for my KD-12.....Steve T. might be able to add to this comment. |
Post# 384971 , Reply# 12   10/13/2009 at 14:57 (5,302 days old) by spiceman1957 ()   |   | |
cut out for such a big task. But something tells me Bob that you will do a great job in restoring this fine machine. Do have pictures and video up on your progress come along. John |
Post# 384980 , Reply# 13   10/13/2009 at 15:28 (5,302 days old) by aldspinboy (Philadelphia, Pa)   |   | |
Post# 385050 , Reply# 14   10/13/2009 at 18:16 (5,301 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
Post# 385114 , Reply# 15   10/13/2009 at 22:04 (5,301 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
Absolutely Not. The tub sizes are drastically different between a UM and a KA from that era. and the difference would be by about 12- 16 " in height. The UM series had a smaller wash chamber because of the 3 1/2 min cycle. The UM is a single rack machine. The wash principle (Pump Spray Arm etc) is the same as a 10, 11 and 12. Because of the upper rack on the Home machines is the reason for a longer cycle. The UM in 3 1/2 min could as I always say take the rust off a trailer hitch. Providing it had at least 170 degree water. There was a model that was the UM4D. The D stood for "Dual water Inlets". It allowed 150* wash water and 180* Rinse. Pain for plumbers and the owner, but it made sense. 180* water would bake on Lipstick during the wash. However the right chemical detergent would get the job done. |
Post# 385150 , Reply# 16   10/14/2009 at 00:45 (5,301 days old) by bobbins (Victoria, BC, Canada)   |   | |
Yes you are correct...the tub differences are 3.5"..to bad...but the power this puppy has will out perform anything new... Here are more pix....the #@$Q@$%@ heavy legs...must be solid metal.. |
Post# 385152 , Reply# 18   10/14/2009 at 00:49 (5,301 days old) by bobbins (Victoria, BC, Canada)   |   | |
more new parts for my UM-4... |
Post# 385153 , Reply# 19   10/14/2009 at 00:50 (5,301 days old) by bobbins (Victoria, BC, Canada)   |   | |
Oh yeah...he had a brand new bottom plate rack - still in the original packaging!!! |
Post# 385179 , Reply# 20   10/14/2009 at 05:54 (5,301 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
Post# 385579 , Reply# 22   10/15/2009 at 15:39 (5,300 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
Post# 385586 , Reply# 23   10/15/2009 at 17:07 (5,299 days old) by bobbins (Victoria, BC, Canada)   |   | |
Yes - two SS channels...no gaskets!!! Bob |
Post# 385634 , Reply# 25   10/15/2009 at 21:36 (5,299 days old) by bobbins (Victoria, BC, Canada)   |   | |
Yes I have many parts for the UM series dishwasher. I actually have 3 timers, 3 rotors, extra screen...nice to have extra parts..... |
Post# 385639 , Reply# 26   10/15/2009 at 22:13 (5,299 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
Post# 385925 , Reply# 28   10/17/2009 at 15:18 (5,298 days old) by christfr (st louis mo)   |   | |
Post# 388379 , Reply# 30   10/26/2009 at 23:08 (5,288 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
Post# 1118928 , Reply# 31   6/1/2021 at 00:00 (1,053 days old) by bobbins (Victoria, BC, Canada)   |   | |
Wow..I can't believe how time flies...took me 12 years to finally get my Hobart UM-4 running! CLICK HERE TO GO TO bobbins's LINK |
Post# 1119063 , Reply# 32   6/2/2021 at 16:06 (1,052 days old) by Hippiedoll ( arizona )   |   | |
Post# 1119065 , Reply# 33   6/2/2021 at 16:25 (1,052 days old) by parunner58 (Davenport, FL)   |   | |
Post# 1119118 , Reply# 34   6/2/2021 at 22:16 (1,051 days old) by bobbins (Victoria, BC, Canada)   |   | |
My next project is to install a window...I am sure there will be abundance of plexiglass in the near future. Fortunately, I have a spare door for the UM-4 and looking at ways to do a cut-out. |
Post# 1119129 , Reply# 35   6/3/2021 at 01:54 (1,051 days old) by Hippiedoll ( arizona )   |   | |
Post# 1119146 , Reply# 36   6/3/2021 at 09:39 (1,051 days old) by parunner58 (Davenport, FL)   |   | |
Robert,
What is the cycle like for your machine? Did it fill and drain just like the home type DW. At Dunkin I would see them load it up, slide in the rack and dump a scoop of detergent on the door and close and turn on. Right out of high school in the mid 70's, I washed dishes while going to college. It was a smaller upscale restaurant and we had a Jackson single rack DW. The cycle was about a 4-5 wash with Eco-Labs Impact detergent and a 2 minute 160 degree rinse with Jet-Dry. Those suckers dried within seconds when you pulled out the rack. I just retired from working in the Disney Resorts Front Desk, I noticed that in the main housekeeping rooms there were Hobart single rack DW's. I looked inside one and looks like they have not used them for years. Hopefully they will end up at property control for sale. I would jump at the chance to buy one. |
