Thread Number: 25133
GE Potscrubber 1200 needs more oomph |
Post# 387768 , Reply# 1   10/24/2009 at 13:34 (5,291 days old) by nmassman44 (Brooksville Florida)   |   | |
Sounds to me that you have a clogged pump inlet or something going your your pump impeller. I would take the sump cover off and check to see what is going on in it. Clean it out and it should restore the power. This dishwasher moves about 35 gallons per minute thru the wash system. Also when your in the sump area feel the grate at the pump opening. Be careful of the chopper spring.
Post# 387776 , Reply# 2   10/24/2009 at 13:54 (5,291 days old) by tlee618 ()   |   | |
I would suggest that you check the water valve and make sure the inlet screen is not clogged. Maybe not enough water is getting into the machine. |
Post# 387804 , Reply# 3   10/24/2009 at 16:14 (5,291 days old) by appnut (TX)   |   | |
Post# 389263 , Reply# 4   10/29/2009 at 22:30 (5,286 days old) by andrewinorlando ()   |   | |
It's possible the pump itself is also worn out and just needs a replacement impeller. Those don't last forever. But I would check that water inlet valve first...these machines need a lot of water to work well. |
