Thread Number: 25173
Do you use dryer sheets? |
Post# 388312 , Reply# 1   10/26/2009 at 17:06 (5,294 days old) by samsungfl (United Kingdom/London )   |   | |
Very True! I used to use dryer sheets quite often, although after a few months I noticed my dryer was getting slower and slower, Ive only got a White Knight Compact Dryer, but waiting 80minutes or so for not even a full load seemed excessive! I did begin to wonder if the dryer was at fault, as its only new and I think we all know about lemon machines! It wasnt until I took the vent hose off the back I found it was so clogged with fluff, easily restricting the airflow! So I gave that a good clean and the tubing that runs into the dryer ( There must of been at least 2 dryer filters worth of fluff in there!). Since this drying times have come down alot so i'm back to fast drying again, which is weird as I was getting used to waiting an age LOL! I Dont use dryer sheets anymore because of this, and the dryer's filter always has alot less fluff on it after a cycle in comparision to with dryer sheets! Ive switched to using Dryer Balls as an alternative now :-) Richard |
Post# 388335 , Reply# 2   10/26/2009 at 18:25 (5,294 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
Anything like the dryer sheets or too much waxy conditioner will start to build up a film all over the drum, usually rendering thermostats & sensors inoperative after a long while... Good to wash them like you say and also if you have excess in the ducting pipe...Cut it and reduce to the minimum...the less venting hose the more efficient the dryer will be!!! keep it straight and no bends..!!! |
Post# 388336 , Reply# 3   10/26/2009 at 18:27 (5,294 days old) by yogitunes (New Jersey)   |   | |
On occassion when I remember, I do use them, and yes once a month I run hot water over the filter and clean the venting, it can build up quickly, but clean your vents anyway for fire safety, dryer sheets or not My sister uses the hell out of them, sometimes 3 and 4 per load, I clean her vent every 6 months and that puppy is packed solid all the way thru her 8 foot pipe, but you can't fix stupid! |
Post# 388344 , Reply# 4   10/26/2009 at 20:04 (5,294 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
I peeped down into my Duet gas dryer's lint filter slit tonight and was shocked to find almost nothing clinging to the sides or bottom of the duct. I ran a vent-brush through the galvanized 7' of pipe from the outside over the weekend and that also was really little more than dust. I very, very rarely use the liquid wax (softener) in the washer and dryer wax sheets are only for display or vacuum bag use. I bought one of those frightful dryer "bars" a few weeks ago and immediately sealed it in a zip bag as soon as it came in the door. We have softened water and with good rinsing, I find the softener is largely unnecessary for most things. A small bit in the sock-load can help with static, but an accurate electronic control dryer is really just as good I've found. |
Post# 388399 , Reply# 6   10/27/2009 at 02:54 (5,294 days old) by launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Post# 388401 , Reply# 7   10/27/2009 at 04:00 (5,294 days old) by dadoes (TX, U.S. of A.)   |   | |
Post# 388471 , Reply# 9   10/27/2009 at 12:02 (5,293 days old) by steve1-18 (Grovetown (Augusta), GA)   |   | |
My friend took some Bounce sheets along on our last camping trip. He rubs a sheet on his arms, neck, and legs (exposed flesh) and tucks the sheet in a belt loop. Keeps the flying critters at bay and smells good, too! |
Post# 388478 , Reply# 10   10/27/2009 at 12:30 (5,293 days old) by pulsator (Saint Joseph, MI)   |   | |
I never ever ever ever use dryer sheets!!! They can make the clothes smell good and I do like the "fresh linen" scent of Bounce and wish it came in liquid fabric softener form but, they do nothing for softness for me! Everything comes out feeling like sand paper to me! I am ADDICTED to the use of liquid fabric softener!!! I know I use quite a bit especially on towels, but if properly washed, there is no build-up on the towels and they are still VERY absorbent! I do check the lint filters regularly to make sure the dryers are getting proper airflow and have never once had to clean them as any water put on them just falls straight through as if passing through air!
Post# 389685 , Reply# 11   10/31/2009 at 09:23 (5,289 days old) by drhardee ( Columbia, SC)   |   | |
Post# 389814 , Reply# 13   10/31/2009 at 19:41 (5,289 days old) by gyrafoam (Wytheville, VA)   |   | |
I only use them every now and then preferring the liquid in the washing machine. In spite of all the gloom and doom stories about constant use of dryer sheets, I know people who have used a gazillion dryer sheets in their old driers, and nary a problem. Go 'figya. |
Post# 389819 , Reply# 14   10/31/2009 at 20:12 (5,289 days old) by qsd-dan (West)   |   | |
I haven't had a dryer sheet touch my clothing since my mother quit using them in the early 90's when I was a kid. "I know people who have used a gazillion dryer sheets in their old driers, and nary a problem. Go 'figya." My grandmother used several sheets per load in her DE806 dryer for several decades and she never had an issue. I have a feeling that wouldn't be the case if the dryer had the older wire wound baffles instead of the newer solid strip ones. |
Post# 389822 , Reply# 15   10/31/2009 at 20:19 (5,289 days old) by alr2903 (TN)   |   | |
Even 1/3 of a dryer sheet will stop static in a huge load of clothes. They DO make towels less absorbent. alr2903 |
