Thread Number: 25334
Maytag water level pushbuttons selector |
Post# 390582   11/3/2009 at 23:53 (5,279 days old) by scrubflex (bronx, new york)   |   | |
Is there anyway to adjust(RESET) and add more water to washtub while using the 806, 606, etc. (LARGE) setting? Supposed you need to add more, what do you do? |
Post# 390593 , Reply# 1   11/4/2009 at 00:38 (5,279 days old) by laundromat (Hilo, Hawaii)   |   | |
Post# 390597 , Reply# 3   11/4/2009 at 01:20 (5,279 days old) by strongenough78 (California)   |   | |
Post# 390598 , Reply# 4   11/4/2009 at 01:30 (5,279 days old) by redcarpetdrew (Fairfield, CA)   |   | |
Just remember, the higher the water level the bigger chance of the washer eating clothing during spin. Ideally, the water level should be right around the top row of holes in the spin tub for the highest setting. Usually, the calls where I have to remove eaten clothing are where the level's too high... RCD |
Post# 390623 , Reply# 5   11/4/2009 at 06:56 (5,279 days old) by scrubflex (bronx, new york)   |   | |
Does any know if "holding the adjusting water level touch control" on the Maytag A9900 or A9904 Digital Computer Touch Control washer will work the same? |
Post# 390627 , Reply# 6   11/4/2009 at 07:21 (5,279 days old) by yogitunes (New Jersey)   |   | |
Post# 390644 , Reply# 7   11/4/2009 at 08:41 (5,279 days old) by kenwashesmonday (Carlstadt, NJ)   |   | |
My A606 is adjusted to fill untill just before the fabric softener cup floats. Ken D. |
Post# 390784 , Reply# 9   11/4/2009 at 16:35 (5,278 days old) by rp2813 (Sannazay)   |   | |
Post# 390794 , Reply# 10   11/4/2009 at 17:11 (5,278 days old) by mixfinder ()   |   | |
I am with you Ken, thats exactly how I like mine. |
Post# 390813 , Reply# 11   11/4/2009 at 18:48 (5,278 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 390860 , Reply# 13   11/4/2009 at 21:49 (5,278 days old) by yogitunes (New Jersey)   |   | |
Holding the digital model pad ony gives you a beep, once filled and satisfied thats it!....if you wanted more water you would have to add it manually with a bucket or hose, otherwise set the screw to where you want it, and let it forever fill to that point...never worry or use the small level....only medium and large....don't forget mine is standard capacity with the 50hz conversion, and I'm using an orbital agitator with a helical drive, that machine can move a load BIG TIME...I watch in amazement everytime! |
