Thread Number: 2572
P.B.Blaster does it again------------ |
Post# 72559 , Reply# 1   7/6/2005 at 19:08 (6,866 days old) by westytoploader ()   |   | |
Cool! PB really came in handy on the 1-18--that and the air impact wrench! Is there a way to get it up under that stubborn Kenmore agitator cap you were talking about at the Convention? |
Post# 72581 , Reply# 2   7/6/2005 at 21:17 (6,865 days old) by Gyrafoam (Wytheville, VA)   |   | |
Well, I guess I could always turn the machine upside down and spray it up under the cap! I Have not yet tried the hot water method either, but will do so to see if it works. |
Post# 72585 , Reply# 3   7/6/2005 at 21:33 (6,865 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 72712 , Reply# 5   7/7/2005 at 15:48 (6,865 days old) by Jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
It was me and you are correct about the osmotic ability. Glenn can you get this stuff down there, I get it at a local Auto Parts store here. I think NAPA may carry it also. ON The pump screws I have used the "Seger Heat to Death Method" and then when they are toasted you put a perfect fit screwdriver in the head then WHACK it straght down with a hammer then immediately using a socket screwdriver you first turn to TIGHTEN--- YES TIGHTEN then immediately turn to loosen. Good luck Jon |
Post# 72715 , Reply# 6   7/7/2005 at 16:29 (6,865 days old) by DADoES (TX, U.S. of A.)   |   | |
I do have a can of PB. Austin sent Mother Venus to fetch it when they were here for the first stab at the WO-65. He doused the screws liberally, but being as the threads hold at the other end in the motor bell, there wasn't any effect. Maybe now that some time has passed a little of it oooooozed and osmosified up to the threads. I can douse them again, and I also have a torch to toast them, just haven't had an opportunity to do it. We shall overcome . . . at some point in time. |
