Thread Number: 25755
KitchenAid Dishwasher....Should I????? |
Post# 395892   11/25/2009 at 15:39 (5,236 days old) by autowasherfreak ()   |   | |
What do you think could be the problem? CLICK HERE TO GO TO autowasherfreak's LINK on Quadcities Craigslist |
Post# 395912 , Reply# 1   11/25/2009 at 18:46 (5,236 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
Post# 395984 , Reply# 2   11/26/2009 at 10:52 (5,235 days old) by autowasherfreak ()   |   | |
I'm going to get it sometime Friday. |
Post# 395997 , Reply# 3   11/26/2009 at 12:40 (5,235 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 396034 , Reply# 4   11/26/2009 at 19:47 (5,235 days old) by redcarpetdrew (Fairfield, CA)   |   | |
Post# 396050 , Reply# 5   11/26/2009 at 21:35 (5,235 days old) by autowasherfreak ()   |   | |
Could it be a bad inlet valve? |
Post# 396136 , Reply# 6   11/27/2009 at 17:09 (5,234 days old) by polkanut (Wausau, WI )   |   | |
Post# 396266 , Reply# 8   11/28/2009 at 13:40 (5,233 days old) by appnut (TX)   |   | |
Post# 396292 , Reply# 10   11/28/2009 at 16:13 (5,233 days old) by appnut (TX)   |   | |
Post# 396294 , Reply# 11   11/28/2009 at 16:23 (5,233 days old) by appnut (TX)   |   | |
This is the Whirlpool version. However, there shouldn't be any difference in loading. The only cycle sequence difference is there are probably 2 full rinses after the main wash instead of one.
CLICK HERE TO GO TO appnut's LINK |
Post# 396300 , Reply# 14   11/28/2009 at 17:12 (5,233 days old) by appnut (TX)   |   | |
Steve, I also believe the water heating phase on Hobart machines (with the little orangeish/red idiot light on the control panel) will not circulate water while it's heating, only pause and "dwell" so to speak until the water temp is reached and then it will begin to pump/circulate water. I have friends who just got rid of the Imperial version of this Hobart machine (it had been ridden verry hard and was beginning to rust in the tank) and it didn't circulate the water during the heating pause.
Post# 396301 , Reply# 15   11/28/2009 at 17:14 (5,233 days old) by autowasherfreak ()   |   | |
I suppose y'all want some picture ;-) |
Post# 396306 , Reply# 16   11/28/2009 at 17:25 (5,233 days old) by autowasherfreak ()   |   | |
Front |
Post# 396307 , Reply# 17   11/28/2009 at 17:25 (5,233 days old) by autowasherfreak ()   |   | |
Inside |
Post# 396308 , Reply# 18   11/28/2009 at 17:29 (5,233 days old) by appnut (TX)   |   | |
Post# 396318 , Reply# 19   11/28/2009 at 18:55 (5,233 days old) by autowasherfreak ()   |   | |
It does have the changeable front panels white, almond, black and my personal favorite harvest gold! |
Post# 396319 , Reply# 20   11/28/2009 at 18:55 (5,233 days old) by swestoyz (Cedar Falls, IA)   |   | |
Post# 396320 , Reply# 21   11/28/2009 at 18:56 (5,233 days old) by autowasherfreak ()   |   | |
Not a bad deal for $10.00 |
Post# 396409 , Reply# 23   11/29/2009 at 11:10 (5,232 days old) by appnut (TX)   |   | |
Post# 396460 , Reply# 24   11/29/2009 at 17:51 (5,232 days old) by autowasherfreak ()   |   | |
I had no problems getting it to fill either, I don't think the previous owners knew how to run it properly, the last time I ran it I pushed the pots & pans cycle and it started right up. |
Post# 396463 , Reply# 25   11/29/2009 at 18:15 (5,232 days old) by appnut (TX)   |   | |
Post# 396541 , Reply# 26   11/30/2009 at 04:23 (5,231 days old) by goatfarmer (South Bend, home of Champions)   |   | |
