Thread Number: 26322
Maytag A606S washer |
Post# 404029 , Reply# 1   1/5/2010 at 16:46 (5,216 days old) by qsd-dan (West)   |   | |
It sounds like a bad timer motor. However, it could be a bad escapement, although it's somewhat rare for them to go bad before replacing at least one timer motor. If you have no troubleshooting experience in the electrical arena, it's best to replace the entire timer itself. Maytag sourced from 2 different timer manufactures (Mallory and Kingston). To make it even more complicated, they used several different timers for the same machine, whether the timer was set up for Permanent Press or not, ect. To top it off, there were even more timer motors and escapements used for each of those applications. If you can respond with some info, I can narrow down which timer (or timer motor) you need. I'll need to know if the timer has the Permanent Press cycle. If it does, that narrows it down to one timer (or timer motor). If it doesn't, I'll more info to narrow down the search. BTW, glad to hear you're willing to save the machine. It'll outlast and outperform just about anything made today! |
Post# 404247 , Reply# 3   1/6/2010 at 15:44 (5,215 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 404251 , Reply# 4   1/6/2010 at 16:14 (5,215 days old) by revvinkevin (Tinseltown - Shakey Town - La-La Land)   |   | |
Post# 404297 , Reply# 5   1/6/2010 at 19:42 (5,215 days old) by qsd-dan (West)   |   | |
Post# 404298 , Reply# 6   1/6/2010 at 19:48 (5,215 days old) by qsd-dan (West)   |   | |
Post# 404720 , Reply# 8   1/8/2010 at 23:22 (5,213 days old) by qsd-dan (West)   |   | |
Give this place a try as they claim to have one in stock. If you have no luck with them, give Larry a call at Modern Parts 216-661-6966 or Buff's Appliance parts and service 856-358-2436.
CLICK HERE TO GO TO qsd-dan's LINK |
