Thread Number: 26503
Lees project |
Post# 406791   1/17/2010 at 09:59 (5,212 days old) by hotpoint95622 (Powys)   |   | |
Up date. Program now finished, used the last PCB I made to prefect the manufacturing processes, then used it to evaluate the program by out puts indicated by the LED’s and the responses from the inputs, step by step, all seems to work as expected. Next is to construct three new PCB’s, one for the front with the switches on and two for behind the front panel to control relays and the inputs from stats and pressure switch. Block diagrams of the programs following. |
Post# 406792 , Reply# 1   1/17/2010 at 10:02 (5,212 days old) by hotpoint95622 (Powys)   |   | |
Post# 406793 , Reply# 2   1/17/2010 at 10:08 (5,212 days old) by hotpoint95622 (Powys)   |   | |
Post# 406796 , Reply# 3   1/17/2010 at 10:14 (5,212 days old) by hotpoint95622 (Powys)   |   | |
Post# 406797 , Reply# 4   1/17/2010 at 10:16 (5,212 days old) by hotpoint95622 (Powys)   |   | |
Post# 406803 , Reply# 5   1/17/2010 at 10:24 (5,212 days old) by hotpoint95622 (Powys)   |   | |
Post# 406805 , Reply# 6   1/17/2010 at 10:27 (5,212 days old) by hotpoint95622 (Powys)   |   | |
Post# 406831 , Reply# 8   1/17/2010 at 12:14 (5,212 days old) by hotpoint95622 (Powys)   |   | |
Never thought of using warm water in the last rinse, suppose I’m used to machines using cold water for this. The lower wash action during heating comes from the early Hotpoint’s. The pump and tumble followed by distribute and a short spin, lengthening with each rinse comes from some early Zanussi machines. I don’t mind you using the charts, at lest one of us may get it to work!!!! |
Post# 407311 , Reply# 9   1/19/2010 at 04:19 (5,210 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
Great work there Lee, does the cold water for the rinsing enter the drum as the drum is coasting down from spin?? or does the valve energise only when the drum is stopped?? Thats my one beef about a lot of machines, they could get rid of so many sudz, say from the first spin after the wash, just by doing this!!! |
Post# 407382 , Reply# 10   1/19/2010 at 11:22 (5,210 days old) by hotpoint95622 (Powys)   |   | |
Not sure about that, there is a 12 second gap between the motor switching off to the pump switching off, so it might just still be rotating. Have toyed with the idea of during the fist drain of the wash water and after the first rinse, allowing the pump to run and energise the cold water at the same time to wash out the soap sudz for 24 seconds. This program is going to change like the wind. |
Post# 409920 , Reply# 11   1/27/2010 at 09:49 (5,202 days old) by hotpoint95622 (Powys)   |   | |
Post# 409921 , Reply# 12   1/27/2010 at 09:50 (5,202 days old) by hotpoint95622 (Powys)   |   | |
