Thread Number: 26573
Maytag pumps |
Post# 407843   1/20/2010 at 20:44 (5,208 days old) by yogitunes (New Jersey)   |   | |
Post# 407858 , Reply# 1   1/20/2010 at 21:26 (5,208 days old) by redcarpetdrew (Fairfield, CA)   |   | |
Post# 407868 , Reply# 2   1/20/2010 at 21:47 (5,207 days old) by alr2903 (TN)   |   | |
My pump growls too. (A206), which screw please? |
Post# 407884 , Reply# 3   1/20/2010 at 22:58 (5,207 days old) by qsd-dan (West)   |   | |
After removing the front cover, get down on the ground and look at the center of the pump straight on at eye level. The screw will be staring directly at you. Use turbine oil ONLY to lubricate!!!!!! I usually remove the screw, put the machine in spin mode, and squirt turbine oil through the hole after the machine has reached its maximum 618 RPM spin speed. I've actually been able to revive pumps that were on the verge of locking up by using this method. |
Post# 407896 , Reply# 4   1/21/2010 at 00:04 (5,207 days old) by alr2903 (TN)   |   | |
Dan, thanks, will certainly give it a try. arthur |
Post# 407915 , Reply# 5   1/21/2010 at 00:50 (5,207 days old) by yogitunes (New Jersey)   |   | |
