Thread Number: 26594
Maytag Water Inlet Valve Assembly |
Post# 408202 , Reply# 1   1/21/2010 at 20:15 (5,201 days old) by qsd-dan (West)   |   | |
Ebay is a a good source for parts. It wouldn't hurt to check a few prices from some parts places that are nearby. Part # is 205613. Swapping the water valve is very straight forward. Turn off water, removed hoses, remove screw (I think it's 1/4 or 5/8) and swing out the assembly. Remove wires from old valve and install onto new valve one by one (there are 4). Remove and install water line (the small skinny one that goes from the water valve to the injector) from old to new valve. Swap water valves to the bracket, and install in reverse. |
