Thread Number: 26718
Best Washing Machine for Lint Removal |
Post# 410412 , Reply# 1   1/28/2010 at 21:20 (5,194 days old) by toggleswitch2 ()   |   | |
I'm just gonna say this once. General Electric Filter-flo. :-) |
Post# 410419 , Reply# 2   1/28/2010 at 21:38 (5,194 days old) by appnut (TX)   |   | |
Post# 410463 , Reply# 3   1/28/2010 at 23:58 (5,194 days old) by scrubflex (bronx, new york)   |   | |
Keep an eye also for a 1972-1974 GE Filter-Flo Versatronic PROGRAMMED FABRIC SELECTION washer that has the timed bleach and fabric softener dispensers. I want this washer. |
Post# 410508 , Reply# 4   1/29/2010 at 03:16 (5,194 days old) by volvoguy87 (Cincinnati, OH)   |   | |
The best lint removal, Bar None! An old Maytag with the turquoise agitator is nothing to sneeze at, but a GE Filter Flow will out perform ANYTHING on the market today or in the past in terms of good lint removal, regardless of efficiency, or top or front loading. A GE Filter Flo (GE FF) works by using the pump to pump the wash water through a flume all through the wash and rinse cycles. The flume dumps the water into a huge filter pan on top of the agitator. You must remove the ball of lint from the filter at the end of the wash cycle. GE FF, it was good then, it's better now, Dave |
Post# 410514 , Reply# 5   1/29/2010 at 05:30 (5,194 days old) by mrb627 (Buford, GA)   |   | |
Why does it seem that for modern washer manufacturers that lint removal is of little concern? Almost a non-issue in the washing machine. And the lint screen in he dryers have gotten smaller. Seems that the older machines used to have ultra large lint screens (like the Whirlpool top pill out that was 3 feet long). Now it is a little square inside the front door. What are they thinking? Malcolm |
Post# 410576 , Reply# 7   1/29/2010 at 11:03 (5,194 days old) by laundromat (Hilo, Hawaii)   |   | |
Agitator washers cause lint. The difference between the tumble type and agitator type washers is irremarkable.I had so many customers that I converted from top to front loaders come back to ask why there was no lint collecting in their new dryer or current one that was originaly drying clothes out of their top loaders.I explained to them that theagitator washer's vigorous agitation with the sharp blades as aposed to the smooth,perforated arms in the front loaders create ware on the fabric and cause the fibers to tare or break which causes lint. Front loaders will more thoroughly remove sediment like dog,cat,human and dust hair easily without taring the fabrics.The clothes rubbing against each other along with gravity and hundreds of perforations in the wash cylinders are how it works.no need for recirculating water or filter pans.I do check my "button trap"once a month but never much lint there. Just a few coins and other debres that had acumulated.The worst case was when I was with my room mate of 12 years,Orma,in florida and a metal part of one of her bras had come apart getting stuck in between the inner and outer tubs.removing the arm in my kitchenAid Ensemble unit helped to get parts of it broken down enough for it to reach the button trap and remove all the residue left.Whirlpool needs to make their button trap accessable to the owner/user instead of having it hidden behind the front service panel.Frigidaire too. |
Post# 410594 , Reply# 9   1/29/2010 at 13:02 (5,194 days old) by volvoguy87 (Cincinnati, OH)   |   | |
My mother has a GE Adora front loading washer and dryer. A normal cycle on the Adora washer is about an hour and a half and it could not remove cat hair! I put my laundry in it with the cat hair and it looked like it hadn't been washed at all once it had been dried. I understand that front loaders are supposed to be easier on the clothes and wash better, but I have yet to experience it in any front loader I have used. I'll stick with my Filter Flo for the linty stuff, Dave |
Post# 410600 , Reply# 10   1/29/2010 at 13:51 (5,194 days old) by toggleswitch2 ()   |   | |
Maybe the gentler wash-action in a tumble washer (front-loader) is gentler, but a super fast 1,000+ RPM spin CAN'T be good on fibers....... |
Post# 410607 , Reply# 11   1/29/2010 at 14:27 (5,194 days old) by ronhic (Canberra, Australia)   |   | |
...between 'lint' which is created during the washing process and animal hair/fur. Front loaders, generally speaking, produce much less actual lint during washing which is why they don't have lint filters. As an example, I have just dried (ok, last night) a full load of mixed items in the dryer and got less than a tightly 'scrunched up tissues' worth of lint off the screen.... Front loaders, however, are not good at removing pet hair....that generally needs water to 'float' them off and a decent filter, such as a GE filter-flo, to catch them. ....which is part of the reason we have 'non-drop' dogs... Go the Soft Coated Wheaten terriers! |
Post# 410796 , Reply# 13   1/29/2010 at 23:36 (5,193 days old) by jons1077 (Vancouver, Washington, USA)   |   | |
Honestly, having both an older filter flo and Maytag, I've noticed a pretty big difference between the filtering abilities as well as two different substances being filtered out of the wash. Ronhic pointed out that "lint" is in fact comprised of small fibers of fabric mostly created by the washing action of the machine. Pet hair is totally different and some ways of filtering work better than others for this. Many say the filter flo is best for removal of lint and pet hair. The difference I've noticed between the Maytag and Filter-Flo is there being generally more LINT found in the filter pan of the GE. The Maytag generally does not produce much lint. This would make some since considering the wash action seems to be more of a gentle nature compared to the GE on normal speed. Our golden retriever has been shedding buckets of hair lately and the hair is on EVERYTHING!!! Particularly, hair is on the bedding. I can say that the GE catches a fair amount of hair, but hair generally seems to float in the wash water. Since the filter stream is pulled from the very bottom of the outer tub, a lot of the hair is being missed and can be seen floating along the upper rim of the inner tub. The Maytag's filtering is completely different and more of a passive approach. On higher water levels the agitator post filtering system is VERY effective with hair removal. I literally have to clean the filter twice (once after the wash and again after rinsing) because it is completely full of dog hair. This most definitely has to be due to the filtering of the water from the center of the wash action, the agitator. Having said all of this I have to say the Filter Flo is great with lint removal and some pet hair, but if it's really pet hair that is a concern the Maytag central agitator filter wins in my books. Just my observation though... Jon |
Post# 410810 , Reply# 14   1/30/2010 at 03:03 (5,193 days old) by alr2903 (TN)   |   | |
Ditto that Jons1077, the lint filter in the barrel type Tag filter, is a pet hair magnet. alr2903 |
Post# 410814 , Reply# 15   1/30/2010 at 03:31 (5,193 days old) by qsd-dan (West)   |   | |
X2 During the beginning of summer when all 4 animals are massively shedding, the couch covers get covered hair and the 712 filters that stuff out like nobody's business. I actually have to stand over the machine and pull the filter out every 3 minutes to peel off the pet hair that wraps around it. This is one of the major reasons I'll NEVER own a front loader! |
Post# 410817 , Reply# 16   1/30/2010 at 03:53 (5,193 days old) by ronhic (Canberra, Australia)   |   | |
Post# 410841 , Reply# 17   1/30/2010 at 07:03 (5,193 days old) by toggleswitch2 ()   |   | |
Toggles, you can't make a statement that applies to every fabric. Carlos: Sure I can. (can means "to be able to"). It just may not be accurate :-) saluti! |
Post# 410907 , Reply# 18   1/30/2010 at 12:54 (5,193 days old) by joelippard (Hickory)   |   | |
Back in the late 80's early 90's Mom had a Filter Flo, we had 2 cats in the house and it really caught alot of lint in the pan, you could see the cat hair in it. I have a Black Labrador Retriever who sleeps with me. I vacuum the sheets off every day, but on wash day I just pitch them in the Frigidaire. The Solid Tub Rollermatic is great at floating that stuff off the top of the water, when the sheets come from the dryer the filter has between 5 and 10 hairs on it. It's not quite as good in the 1-18 but the filter in it does catch a great deal. I can't imagine trying to get rid of hair without alot of water and a filter to aid the process. |
Post# 410911 , Reply# 19   1/30/2010 at 13:08 (5,193 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Belt drive WP&KM washers with self cleaning back wash filters.I would often demonstrate the effectiveness of this type of filter by holding a dryers lint filter under the drain hose as it went into drain you would instantly see 10 times the lint that a FF or MT would catch in thier entire cycle. WP washers have much larger wholes in there tubs than MT and many more wholes than the tubs of GE washers. The FF lint filter sifts most of the lint back through the filter because the pan is moving with the agitator. You can put some dryer lint in the FF pan @ the start of the cycle and you will end up with less lint by the end of the load. The MT filters were so ineffective that about one half of owners never even bothered to clean them @ all. How many of us found old MTs where the filer was stuck in the agitater? owners soon stopped cleaning after seeing almost no lint on them load after load. I sold and serviced MT through the1970s.
Post# 411802 , Reply# 20   2/1/2010 at 18:09 (5,191 days old) by surgilator_68 (Maryland)   |   | |
Why? Just because it has a great big pan and you get balls of lint? Ever look at that lint? It's all the large stuff that can't make it thru the holes. Put a stocking on the end of the hose or the lint filter from the dryer under the drain hose and see how much is actually sifted thru that filter returning to the water in the washer. It's like sifting flour with a strainer. Shake the strainer enough and you are left with the clumps.
Post# 411839 , Reply# 21   2/1/2010 at 20:02 (5,191 days old) by scrubflex (bronx, new york)   |   | |
Have you actually done this? If so, what did you do? |
Post# 411892 , Reply# 22   2/2/2010 at 02:49 (5,190 days old) by lordkenmore (The Laundry Room)   |   | |
From from modern, but I really liked the one belt drive Kenmore user-cleaned filter I used. I moved into a place that had a machine like this. My around the house clothes were covered with enough fur to knit a couple of dogs. (My roommate at my previous residence had several dogs and 3 cats!) One trip through the washer, and that fur was GONE. I was really amazed...I figured the washer would work better than what I'd used before (WCI Frigidaire), but it did much, much better. That design probably didn't catch everything, but my clothes (which are mostly air dried) had almost no visible lint or fur. Which is more than good enough for me. |
Post# 1153540 , Reply# 23   7/6/2022 at 19:04 (653 days old) by GELaundry4ever (Nacogdoches, TX, USA)   |   | |
GE filter-flo is the best washer EVER, hands down! Perfect for washing smelly clothes and dirty blue jeans and overalls. |
Post# 1153657 , Reply# 27   7/8/2022 at 07:13 (651 days old) by ozzie908 (Lincoln UK)   |   | |
Honeycomb drum as iej says above the drum is designed to be gentle on clothes but it does retain a lot of the hair as it is unable to go through the holes...
I have a Whirlpool Dreamspace not sure how old it is but it keeps going and that does a wonderful job on pet hair it has lots of holes in the drum and what that doesn't remove my 20 year old SQ dryer gets the rest. Sorted |
Post# 1153667 , Reply# 29   7/8/2022 at 09:30 (651 days old) by Maytag85 (Sean A806)   |   | |
