Thread Number: 26799
Unimatic Water Valve |
Post# 411697   2/1/2010 at 10:50 (5,197 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
I have not touched the Unimatic for a couple of weeks. So, today I decided to figure stuff out. John(coldspot66) and I were visiting and had this water valve from a early Whirly or Kenmore. It looks pretty similar to the New/Old Valve I got from Modern Parts that leaks. I have not tested it yet to find out why it leaks. However the valve John gave me doesn't leak. So electrically do you Uni Guys think this will work ? |
Post# 411698 , Reply# 1   2/1/2010 at 10:51 (5,197 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
Post# 411700 , Reply# 2   2/1/2010 at 10:52 (5,197 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
Post# 411734 , Reply# 4   2/1/2010 at 12:54 (5,197 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
Post# 411739 , Reply# 6   2/1/2010 at 13:12 (5,197 days old) by unimatic1140 (Minneapolis)   |   | |
Post# 411752 , Reply# 8   2/1/2010 at 14:23 (5,197 days old) by swestoyz (Cedar Falls, IA)   |   | |
Yep - as Robert said it should work fine. Electrically should work hot/warm, however the output flow may differ due to it being set-up originally for a WP. You'll know when it starts overflowing excessively before the washer starts pulsating. This can be corrected by throttling down the output with a ball valve between the water valve and the fill flume. Ben |
