Thread Number: 27211
New Miele W4842 & T9822 |
Post# 417996   2/23/2010 at 19:18 (5,174 days old) by mieleforme ()   |   | |
They will be here tomorrow and I cant wait! |
Post# 418010 , Reply# 1   2/23/2010 at 20:29 (5,174 days old) by Pulsator (Saint Joseph, MI)   |   | |
Post# 418033 , Reply# 2   2/23/2010 at 21:02 (5,174 days old) by appnut (TX)   |   | |
Post# 418035 , Reply# 3   2/23/2010 at 21:03 (5,174 days old) by appnut (TX)   |   | |
Post# 418111 , Reply# 5   2/24/2010 at 07:49 (5,174 days old) by appnut (TX)   |   | |
Post# 418120 , Reply# 6   2/24/2010 at 08:27 (5,174 days old) by favorit ()   |   | |
check THS Laundry forum - user moon1234 made a cut-and paste from it |
Post# 418249 , Reply# 8   2/24/2010 at 18:28 (5,173 days old) by appnut (TX)   |   | |
Post# 418334 , Reply# 11   2/25/2010 at 00:57 (5,173 days old) by mieleforme ()   |   | |
Decided to pop the top off before I started them up ( two screws, 3 min) |
Post# 418336 , Reply# 12   2/25/2010 at 00:59 (5,173 days old) by mieleforme ()   |   | |
inside#2 |
Post# 418337 , Reply# 13   2/25/2010 at 01:01 (5,173 days old) by mieleforme ()   |   | |
Installed |
Post# 418467 , Reply# 16   2/25/2010 at 14:55 (5,172 days old) by nmassman44 (Brooksville Florida)   |   | |
As far as the washer goes adjust what you want. I tried to reprogram my 4800 and it wont work. But on the dryer you may find that it wont need reprogramming. Try it the way it is straight from the factory first. Oh and you wont need an extra 10 mins for cooldown. The clothes are room temp when the dryer stops. The other thing I have to stress is DONT USE DRYER SHEETS!! The powder from the sheets clog the filter and impede the airflow and you will hear it. Enjoy your set.
Post# 418491 , Reply# 17   2/25/2010 at 16:44 (5,172 days old) by Rolls_rapide (.)   |   | |
Nice machines. They have an understated elegance about them. Happy washing! |
Post# 418504 , Reply# 18   2/25/2010 at 17:43 (5,172 days old) by vacfanatic ()   |   | |
The insides look similar - here is the smaller W3033 model for the USA. Love mine!!! Andrew |
Post# 418523 , Reply# 19   2/25/2010 at 18:00 (5,172 days old) by mieleforme ()   |   | |
yea, I'm not noticing my selection being changed. Wonder why that is? It is doing a good job however. |
Post# 418526 , Reply# 20   2/25/2010 at 18:12 (5,172 days old) by ronhic (Canberra, Australia)   |   | |
Post# 418527 , Reply# 21   2/25/2010 at 18:13 (5,172 days old) by nmassman44 (Brooksville Florida)   |   | |
With mine I got the repair manual and I am thinking that maybe the manuals have been superceded by another updated manual. Nothing what they said to do worked. One thing with the washer is you may find that you wont need the Extended wash option. I never use mine since the HydroMatic wash action is so powerful that it will over work your clothes and they will come out looking very tired. Plus it extends the total wash time to about 2+ hours.
The dryer is very fast. I have the electric 9800 and the load rarely ever gets above body temp. Stop the dryer about midway thru the cycle and you will see that the load isnt hot like in other dryers. They work as a team and I always use the Max spin speed. That alone makes the dryer do its job fast. The dryer will be done before the washer is. And one other thing. When using the dryer make sure you can open a window near the dryer to let fresh air into the room. This dryer will pull all the heat out of your house in the wintertime. And in no time flat too. If you hear the fan struggling to get proper airflow thru the drum it is very noticeable in the sound. As you use the dryer you will see what I mean. |
Post# 418619 , Reply# 25   2/25/2010 at 21:32 (5,172 days old) by mysteryclock (Franklin, TN)   |   | |
It was mentioned over in the archived thread below (which contains more disassembly pics, btw) that the tub is actually a kind of fiberglass so it should be quite durable since they make boats out of that stuff. The other stated benefit (besides bleach resistance) is that it helps hold the heat in better than a single-wall stainless tub, which is especially important with the larger sized tub. Considering it only has a 120v heater onboard, the more help it can get from the design keeping all that volume heated the better. That's probably less of an issue on the EU sized machines given the smaller capacity.
CLICK HERE TO GO TO mysteryclock's LINK |
Post# 418932 , Reply# 27   2/27/2010 at 07:40 (5,171 days old) by mieleforme ()   |   | |
CLICK HERE TO GO TO mieleforme's LINK |
Post# 418947 , Reply# 28   2/27/2010 at 09:28 (5,171 days old) by appnut (TX)   |   | |
Post# 419231 , Reply# 29   2/28/2010 at 12:27 (5,170 days old) by mieleforme ()   |   | |
Moving vids to a new youtube account just for all this washer stuff. My previous link wont work for long. CLICK HERE TO GO TO mieleforme's LINK |
Post# 419334 , Reply# 30   2/28/2010 at 16:43 (5,169 days old) by mrb627 (Buford, GA)   |   | |
Post# 419597 , Reply# 31   3/1/2010 at 14:46 (5,168 days old) by paulc (Edinburgh, Scotland)   |   | |
Post# 420600 , Reply# 32   3/5/2010 at 01:04 (5,165 days old) by mieleforme ()   |   | |
Photos with the Drum lights. CLICK HERE TO GO TO mieleforme's LINK |
Post# 423022 , Reply# 33   3/16/2010 at 17:26 (5,153 days old) by mieleforme ()   |   | |
Reverse tumble starts at the end of the cycle in this video. CLICK HERE TO GO TO mieleforme's LINK |
Post# 423027 , Reply# 34   3/16/2010 at 17:43 (5,153 days old) by bertrum ()   |   | |
Very shocked Miele have gone down the plastic tub route as well!. Very sad, I suppose even Miele are on the cost cutting slippery slope as well. Check your pockets or it could be a new machine is my advice! |
Post# 423079 , Reply# 36   3/16/2010 at 21:40 (5,153 days old) by appnut (TX)   |   | |
Post# 423088 , Reply# 38   3/16/2010 at 22:04 (5,153 days old) by appnut (TX)   |   | |
Post# 423136 , Reply# 40   3/17/2010 at 05:57 (5,153 days old) by logixx (Germany)   |   | |
Post# 423183 , Reply# 42   3/17/2010 at 12:18 (5,153 days old) by Somonica ()   |   | |
Have anyone here try the Swedish mode with their W48XX yet? Soft water made more effective wash? less wash time? more rinse time / water level? |
Post# 423198 , Reply# 44   3/17/2010 at 13:38 (5,153 days old) by Bernina (Chicago)   |   | |
If you ask me, your English is favoloso! : ) Hope I spelled that right. |
