Thread Number: 27216
Solid tub machines |
Post# 418154 , Reply# 2   2/24/2010 at 12:04 (5,146 days old) by rickr (.)   |   | |
Post# 418180 , Reply# 3   2/24/2010 at 13:48 (5,146 days old) by joelippard (Hickory)   |   | |
Post# 418384 , Reply# 4   2/25/2010 at 08:16 (5,145 days old) by ingliscanada ()   |   | |
This will be very intriguing to see:) Gary |
Post# 418441 , Reply# 6   2/25/2010 at 13:08 (5,145 days old) by mickeyd (Hamburg NY)   |   | |
the return is automatic, with no need to manually move the timer and operated during the fill portion of the cycle. It takes 4 minutes to return the suds to match the usual fresh water 4 minute fill time; hence, the weak small slow pump. The return is selected on the Wash Temp Control: "Hot- Warm- Cold- Suds Water Saver" were the readings on Aunt Ellen's Mid -60's Multimatic.
Rick's new beauty looks like it works the same way, although his has a separate control. Can't wait to find out. Ditto, Kelly, no drama! No agitation, cool noises, etc., nothing like the excitement of a WP/KM. I'll have pix soon of a few solid tubs. |
Post# 418503 , Reply# 7   2/25/2010 at 17:42 (5,145 days old) by joelippard (Hickory)   |   | |
Post# 418505 , Reply# 8   2/25/2010 at 17:44 (5,145 days old) by joelippard (Hickory)   |   | |
Post# 418506 , Reply# 9   2/25/2010 at 17:45 (5,145 days old) by joelippard (Hickory)   |   | |
Post# 418507 , Reply# 10   2/25/2010 at 17:46 (5,145 days old) by joelippard (Hickory)   |   | |
Post# 418508 , Reply# 11   2/25/2010 at 17:47 (5,145 days old) by joelippard (Hickory)   |   | |
Post# 418509 , Reply# 12   2/25/2010 at 17:48 (5,145 days old) by joelippard (Hickory)   |   | |
Post# 418510 , Reply# 13   2/25/2010 at 17:48 (5,145 days old) by joelippard (Hickory)   |   | |
Post# 418511 , Reply# 14   2/25/2010 at 17:49 (5,145 days old) by joelippard (Hickory)   |   | |
Post# 418512 , Reply# 15   2/25/2010 at 17:49 (5,145 days old) by joelippard (Hickory)   |   | |
Post# 418513 , Reply# 16   2/25/2010 at 17:51 (5,145 days old) by joelippard (Hickory)   |   | |
Post# 418514 , Reply# 17   2/25/2010 at 17:52 (5,145 days old) by joelippard (Hickory)   |   | |
Post# 418515 , Reply# 18   2/25/2010 at 17:52 (5,145 days old) by joelippard (Hickory)   |   | |
Post# 418516 , Reply# 19   2/25/2010 at 17:53 (5,145 days old) by joelippard (Hickory)   |   | |
Post# 418517 , Reply# 20   2/25/2010 at 17:54 (5,145 days old) by joelippard (Hickory)   |   | |
Post# 418518 , Reply# 21   2/25/2010 at 17:55 (5,145 days old) by joelippard (Hickory)   |   | |
Post# 418519 , Reply# 22   2/25/2010 at 17:55 (5,145 days old) by joelippard (Hickory)   |   | |
Post# 418520 , Reply# 23   2/25/2010 at 17:57 (5,145 days old) by joelippard (Hickory)   |   | |
Post# 418521 , Reply# 24   2/25/2010 at 17:57 (5,145 days old) by joelippard (Hickory)   |   | |
Post# 418522 , Reply# 25   2/25/2010 at 17:58 (5,145 days old) by joelippard (Hickory)   |   | |
Post# 418539 , Reply# 26   2/25/2010 at 18:34 (5,145 days old) by mickeyd (Hamburg NY)   |   | |
What a great shot--the de facto or faux spray rinse.
You call the 65 a brute. Is it because of the faster spin wind-up or because she has a few battle scars? The blue specked tubs are my favorites, either way. Thanks for the colorful dramatic pix, Joel. Sorry. I now know that you're Joe, but you've been Joel in my head forever. Old habits die hard. ;-> |
Post# 418541 , Reply# 27   2/25/2010 at 18:43 (5,145 days old) by rickr (.)   |   | |
Post# 418546 , Reply# 28   2/25/2010 at 19:07 (5,145 days old) by bajaespuma (Connecticut)   |   | |
Post# 418550 , Reply# 29   2/25/2010 at 19:19 (5,145 days old) by joelippard (Hickory)   |   | |
I call the '65 the Brute, because of it's aggressive nature, it's louder and less gracious than the Rapidry machine, it certainly does have it's battle scars around the tub lip as it was used in very rusty water, the inlet screens were clogged with rust when I got it. I love how loudly it slaps water against the outer tub when it's ramping up to spin, and it's more prone to vibrations than the Rapidry, especially if you forget to load it the "Frigidaire Way"
I'm really surprised how much they hold, more than it would appear they do. I had 6 pairs of pants going in the Rapidry, and 14 shirts in the '65. I've been thinking I'd like to have a '55 Unimatic to go with the '55 Filtrator, they're such a pretty design. I've shyed away because of how hard everyone says they are to work on, but since I've been to Frigidaire Hell with the Rapidry, and done a pump job and minor roller work on the '65 I think I could do anything I need to with enough time and patience. |
Post# 418638 , Reply# 31   2/25/2010 at 23:10 (5,145 days old) by ingliscanada ()   |   | |
...I won't give up my day job to be a comedian:D |
Post# 418658 , Reply# 32   2/26/2010 at 01:27 (5,144 days old) by alr2903 (TN)   |   | |
Joe, thanks for all the pictures of your machines, Your Frigidaires are well taken care of. Thanks again arthur/alr2903 |
Post# 418682 , Reply# 33   2/26/2010 at 07:58 (5,144 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 420315 , Reply# 34   3/4/2010 at 07:45 (5,138 days old) by ingliscanada ()   |   | |
One washer I always wanted to see in action is the old Maytag AMP. |
Post# 420334 , Reply# 35   3/4/2010 at 10:10 (5,138 days old) by mickeyd (Hamburg NY)   |   | |
Post# 420335 , Reply# 36   3/4/2010 at 10:13 (5,138 days old) by mickeyd (Hamburg NY)   |   | |
Post# 420336 , Reply# 37   3/4/2010 at 10:19 (5,138 days old) by mickeyd (Hamburg NY)   |   | |
Post# 420343 , Reply# 38   3/4/2010 at 10:24 (5,138 days old) by mickeyd (Hamburg NY)   |   | |
