Thread Number: 27256
Lint filter on recent SQ TL's |
Post# 418874 , Reply# 2   2/26/2010 at 21:39 (5,170 days old) by nmassman44 (Brooksville Florida)   |   | |
The filter in an SQ washer is under the washbasket. Much like what Whirlpool has but this is a disc not a ring. The holes on the washbasket under the agitator allow the water to be pulled thru the filter and back into the washbasket. The agitator as it moves back and forth the bottom vanes create a surging water action that cause a vacuum effect on the filter. During the start of the spin the filter is swirled clean and the lint goes down the drain.
Post# 418875 , Reply# 3   2/26/2010 at 21:41 (5,170 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 418950 , Reply# 6   2/27/2010 at 09:42 (5,169 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 418955 , Reply# 7   2/27/2010 at 10:13 (5,169 days old) by nmassman44 (Brooksville Florida)   |   | |
Post# 418994 , Reply# 8   2/27/2010 at 14:25 (5,169 days old) by yogitunes (New Jersey)   |   | |
Post# 419000 , Reply# 10   2/27/2010 at 15:02 (5,169 days old) by nmassman44 (Brooksville Florida)   |   | |
There is no place to put the lube..its on a drive bell and the agitator clips onto the drive bell. When I had my Amana washer I got it off but in the process hit my chin with the top of the agitator...and that was painful. One thing I want to do is to get a solid curved vane agitator since I am not so thrilled with the flex vanes on this machine. It catches lint and pulls towels. But other than that its not too shabby.
Post# 419026 , Reply# 11   2/27/2010 at 17:00 (5,169 days old) by rapunzel (Sydney)   |   | |
I usually just grab it firmly around the center post and pull it straight up. It takes a little strength, but can be done without too much trouble. Olav |
Post# 419175 , Reply# 12   2/28/2010 at 09:02 (5,168 days old) by surgilator_68 (Maryland)   |   | |
The SQ does have a lint filter under the wash tub. I call it the hat filter. It fits over the hub and then the tub sits on that. It looks like a straw sun hat with the portion for your head cut off.
However I would not take anything apart to clean anything. As long as it's draining there is no problem. |
Post# 419178 , Reply# 13   2/28/2010 at 09:06 (5,168 days old) by surgilator_68 (Maryland)   |   | |
Post# 419223 , Reply# 14   2/28/2010 at 11:58 (5,168 days old) by JeffG ()   |   | |
Jason and all, thanks again. Great info and advice, as usual! |
Post# 419224 , Reply# 15   2/28/2010 at 11:58 (5,168 days old) by yogitunes (New Jersey)   |   | |
Do you really think those types of filters are actually working or trapping lint and self-cleaning?....better yet, If you ever have the machine apart, take out his filter, think there will be any real difference?...I have taken out several self-clean types and connected the hoses together, no one even knew the difference....do you think this filter, or any for that matter, allow you to wash a white towel with dark permanent press, and keep the lint from attaching to the PP?
think these types would also work at trapping food particles from my dishwasher if I stack it with the plates? |
Post# 419232 , Reply# 17   2/28/2010 at 12:33 (5,168 days old) by yogitunes (New Jersey)   |   | |
Jeff....my point is the average person may leave a washcloth by accident in the machine, and then complain that the lint attached to their clothing, and yet wonder why the filter didn't do it's job...
people like you and I know how to wash and sort properly to reduce if not eliminate lint problems... Overflo rinses were probably the best, filter flo's eith with a pan or brush were also very effective, as well as TRUE magic clean filters with a reversing flush worked well at reducing the amount of lint... I'm just not convinced of a contraption just sitting there, and water currents from the agitator and clothes is what makes it work and clean itself.... yet we could go on and on...but you have to wonder, and I know and have seen water currents pushed into the outter tub during agitation, I just find that many machines like GE filter flo, and Whirlpool/Kenmore non self clean are more effective by pulling water from the outter tub and returning it to the inner wash basket a true use and function of water being filtered.... TRUE self clean types pull water from the outter tub and return it to the outter tub, just not as effective and what really gets me, and I know collecting lint from a filter is slimmy, gross, yucking, etc., people who complain about touching the lint....versus...clogs drains, septic, and traps, I think I would rather have to clean a small filter compared to tearing into the drain lines or paying a plummer to fix an issue like this....yet these same people clean the lint trap in the dryer, and how about hair in the bathroom sink, better yet the sludge/hairy/stringy gunk in the tub drain |
Post# 419291 , Reply# 19   2/28/2010 at 14:31 (5,168 days old) by mtn1584 (USA)   |   | |
Jeff, Are you going to buy better quality blankets though? LOL Mike |
Post# 419293 , Reply# 20   2/28/2010 at 14:39 (5,168 days old) by JeffG ()   |   | |
Mike, yes absolutely. :-) The washer survived, and fortunately the house is plumbed so the washer drain doesn't run through our septic tank. I'd hate to deal with a clogged drain field due to a $15 blanket. |
Post# 419435 , Reply# 22   2/28/2010 at 22:30 (5,168 days old) by surgilator_68 (Maryland)   |   | |
I don't really know about the filters ability to actually do anything. I can say that when I had the T/L I did not have any linting issues at all.
When you get the Maytag, er, um Whirlpool kit to repair the tub seal and drive hub it tells you to throw out the lint filter as it is not needed. The Speed Queen instructions tell you to set the filter aside and put it back into position when reassembling. I personally have never seen one of these filters that was not clogged and coated in mineral build up. Although it's the ones that aren't clogged and coated that actually last. Who woulda thunk? |
Post# 419439 , Reply# 23   2/28/2010 at 22:39 (5,168 days old) by DADoES (TX, U.S. of A.)   |   | |
I recently disassembled and refurbished a DD Kenmore with the original-style under-basket strainer/filter, and it did have some lint caught in it. However, I opted not to reinstall the filter. I ran a large load (7 pairs) of jeans in my Neptune TL recently, drained into a bathtub (running the machine in my master bath). I had the drain stoppered to see what was the total water use, and was surprised how much blue denim lint was floating in there. |
Post# 419445 , Reply# 24   2/28/2010 at 23:00 (5,168 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
