Thread Number: 27315
GE Big-Load Dryers |
Post# 419646   3/1/2010 at 17:14 (5,140 days old) by macboy91si (Frankfort, KY)   |   | |
Post# 419651 , Reply# 1   3/1/2010 at 17:22 (5,140 days old) by laundromat (Hilo, Hawaii)   |   | |
Post# 419652 , Reply# 2   3/1/2010 at 17:24 (5,140 days old) by bobbyderegis (Boston)   |   | |
Tim: They are great! Very large, fairly fast, and very quiet. The gas models use more gas than other brands(30,000 btu's), but they dry faster. Bobby in Boston |
Post# 419656 , Reply# 3   3/1/2010 at 17:28 (5,140 days old) by macboy91si (Frankfort, KY)   |   | |
Just one from the ad, it's small, but it appears to be in good shape. I'm thinking of replacing the Hotpoints with a true Filter-Flo set and I have a lead on a washer as well. The washer has the same console but 2 rocker switches on the left, and 2 knobs in the middle. I like the Hotpoint set OK and there's nothing badly wrong with them, but I just have a preference for a GE set, and the big-load unit is different.
-Tim |
Post# 419658 , Reply# 4   3/1/2010 at 17:32 (5,140 days old) by yogitunes (New Jersey)   |   | |
Post# 419660 , Reply# 5   3/1/2010 at 17:37 (5,140 days old) by bobbyderegis (Boston)   |   | |
Tim: That looks like a TOL model. Does it have the electronic sensor? I'd grab it! Bobby in Boston |
Post# 419661 , Reply# 6   3/1/2010 at 17:42 (5,140 days old) by macboy91si (Frankfort, KY)   |   | |
Well, ever since the lint discussion it's got me wanting an actual Filter-Flo set. You offering me some FF parts for my HP didn't help :) I like the Hotpoints, they're certainly good machines, but the GE's are more gadgety, the washer looks like it could be a mini-basket model. I don't care about speeds, a 1-speed is good, but it looks like the machine I'm looking at is a 2 speed. 2 rockers on the left, 1 or 2 knobs in the center and the timer. I'm GUESSING that the switches are speed on the top and temp on the bottom (C,W,H) and the knobs are infinite water level and extra rinse? I can't tell what's next to the left knob in the center section. I have requested a pic of the washer. I also can't tell if that washer and dryer is almond or white.
-Tim |
Post# 419667 , Reply# 8   3/1/2010 at 17:51 (5,140 days old) by yogitunes (New Jersey)   |   | |
Post# 419668 , Reply# 9   3/1/2010 at 17:53 (5,140 days old) by macboy91si (Frankfort, KY)   |   | |
I wonder if there is any chance of getting a mini-basket on this one? I'm also assuming it's a rampie? My current Hotpoint is an Extra Large Capacity, model, this is a standard cap I'm also assuming. I have no prob with the standard caps, the XL uses a LOT of water on full and I'm a single guy. Although it would be interesting pairing this washer with a big-load dryer :) I've also located a matching (I think) dryer for this machine but I can't tell if that's wood-grain or chrome around the console. I must be going blind.
-Tim |
Post# 419674 , Reply# 10   3/1/2010 at 18:18 (5,140 days old) by yogitunes (New Jersey)   |   | |
Watch yourself on the descriptions of capacities.....at one time there was standard and large....now theres large and extra large....same tubs, just a gimmick...forget the names...look at the tub itself, shallow or deep
I always preferred to go with the biggest capacities available, you can always reduce the water level, but you can't make a small tub larger....people used to ask me why a big machine for one or two people years ago, and this is why....that mini-basket would be better for you than you think...quick loads in 15 minutes...and the larger capacity gives you a larger MINI also |
Post# 419680 , Reply# 12   3/1/2010 at 18:26 (5,140 days old) by macboy91si (Frankfort, KY)   |   | |
Yeah I've noticed all of the names. The 1999 Commercial set I sold to get the HP's were "Super" capacity. They were however, I could stick my whole arm in them, but I didn't like them. They worked fine, but they only had 3 water levels and they were horribly planned. Small was too small and thrashy to wash anything and medium was deceptively low coming in at under half full.
The HP I have now is the deep tub, I'd guess the one I'm looking at is shallow. I don't know how far up the model line you have to go before you get the deep tub. Tom: My standard HP dryer does that with linty things, the lint filter is kinda too small almost. I get a lot of light lint around the door gasket. -Tim |
Post# 419684 , Reply# 13   3/1/2010 at 18:31 (5,140 days old) by appnut (TX)   |   | |
Tim, that looks like the exact same dryer I had, color and all. Bought April, 1978. The two little buttons on the right next to the timer dial are for extra care on or off and signal on or off. I liked this dryer a lot and it has the electronic sensor, will say it on the control panel too. The dryer is white. That GE washer you have pictured in 419661 is a standrd capacity washer. The two toggle switches are 3 speed combos and 3 wash/rinse temp combos. It should have a mini basket. The little knob is the water level. It looks to be almoond too.
Post# 419685 , Reply# 14   3/1/2010 at 18:34 (5,140 days old) by macboy91si (Frankfort, KY)   |   | |
Post# 419687 , Reply# 15   3/1/2010 at 18:37 (5,140 days old) by bajaespuma (Connecticut)   |   | |
I agree with everything Tom just said; the lint is messier than on their standard sized dryers and it is a pain not being able to slide a laundry basket in front of them. For me, it's been a great dryer. It's fast on most cycles but I think the electronic sensor needs calibration. It's also quite large, I measured it at a little more than 7.25 cu ft. What's nice about the big boys is that the surplus is in the diameter of the dryer drum, so the laundry has farther to fall into the air stream and stays better separated.
I'd like to find a gas model someday. |
Post# 419688 , Reply# 16   3/1/2010 at 18:40 (5,140 days old) by appnut (TX)   |   | |
tim, the Extra Care is the extended tumble after cool down. On the Regular/Perm Press Cycle it's like 20 minutes (the cycle on the upper right hand of the timer). The Poly/Knits cycle (upper left of the cycle) is like for 10 minutes more. The buzzer is either on or off, no inbetween setting like on your Hotpoint. And it starts at about 1.5 to 2 minutes before the cycle ends. If extra care is selected on, then that buzzer continues for another 2 or 3 minutes into the beginning of the Extra Care phase. Loud enough to wake the dead. I don't think mine ever buzzed for the entire 4 minutes when EC selected--lived in apartment fot the first two years I had the set and as sensitive about how noisy it was with neighbors. My first house3, laundry was in the garage and the dryer was right next to the door that went into th4e garage from the house, so I still heard the dryer buzzing quite well.
Post# 419690 , Reply# 17   3/1/2010 at 18:43 (5,140 days old) by appnut (TX)   |   | |
Post# 419704 , Reply# 18   3/1/2010 at 19:53 (5,140 days old) by macboy91si (Frankfort, KY)   |   | |
Post# 419716 , Reply# 19   3/1/2010 at 20:52 (5,140 days old) by appnut (TX)   |   | |
So, the washer in 419661 and dryer in 419656 are the "set"? If they are being sold together, the answer is no, they are not a matched set. The washer is standard capacity and the dryer is extra large cpacity. My sister bought a townhouse in Houston in 1977 that came with GE appliances. Although they were both almond, they weren't a matched set. The washer looked similar to the one above, but only had two toggle switches, no little knob for water level. The dryer was the std. capacity version of the big load dryer abo ve, except Press Care and Signal were two small knobs in the center of the panel (like a water level & 2nd rinse). (confused??) The dryer in 419668 is from the 1980s.
Post# 419725 , Reply# 20   3/1/2010 at 21:40 (5,140 days old) by bosch2460 (Harrisonburg, VA)   |   | |
I have that exact washer. The matched set, actually. If it is like mine, it is only a large, standard capacity. Mine dates from 1979. I love it. The only bad part is that parts like an agitator or mini basket are a pain the ass to find. I am still on the hunt for a mini basket that will even fit mine. Good washers, though. :)
Joel |
Post# 419738 , Reply# 21   3/1/2010 at 23:16 (5,140 days old) by alr2903 (TN)   |   | |
Tomturbomatic is right, the door was already half way designed to accomodate that big round filter like Speed Queen use to put on their machines, back in the McGraw-Edison period. alr2903 |
Post# 419751 , Reply# 22   3/2/2010 at 01:03 (5,140 days old) by macboy91si (Frankfort, KY)   |   | |
