Thread Number: 27345
Anyone have experience with the new full-sized Bosch Vision washers? Why the manufacturer's rebates? |
Post# 420034 , Reply# 1   3/3/2010 at 10:04 (5,165 days old) by mysteryclock (Franklin, TN)   |   | |
I have a Nexxt 500 and it looks like they did a major redesign of the Vision washer. It is now a non-tilted horizontal axis washer with front controls, a redesigned detergent drawer, smaller paddles and can even be stacked! The Vision dryer looked the same inside the drum as my Nexxt, but I don't know if they've made any internal changes.
As far as I know they are still made in New Bern, NC, so I wouldn't suspect that quality slipped dramatically from the Nexxt series unless they totally cheaped out on the internals. And I can't imagine why they wouldn't be rated that well in CR, although I have about zero trust for their rankings since otherwise identical products can vary, dramatically, year over year for no good reason. |
Post# 420138 , Reply# 4   3/3/2010 at 15:42 (5,164 days old) by mysteryclock (Franklin, TN)   |   | |
I've never had mine stop and drain in an oversuds situation but I have had it go into "suds reduction" (probably +cooling) mode when things got too foamy, and that really extends the wash cycle. The key I've found is to *always* use a low-sudsing detergent or it'll take twenty forevers to finish a load.
PassatDoc - "bollard", so that's what those things are called! We have one (almost certainly by code) bolted and concrete filled as a Maginot Line in front of our hot water heater, so to speak. |
