Thread Number: 27391
KitchenAid KDC-17A pulled from The Pile |
Post# 420573   3/4/2010 at 22:45 (5,158 days old) by redcarpetdrew (Fairfield, CA)   |   | |
Post# 420574 , Reply# 1   3/4/2010 at 22:47 (5,158 days old) by redcarpetdrew (Fairfield, CA)   |   | |
Post# 420577 , Reply# 2   3/4/2010 at 22:49 (5,158 days old) by redcarpetdrew (Fairfield, CA)   |   | |
Post# 420579 , Reply# 3   3/4/2010 at 22:53 (5,158 days old) by redcarpetdrew (Fairfield, CA)   |   | |
The wash arm. Sounds just like a Kitchenaid by Hobart. I still love the description "Hurricane In A Box". This one sounds like it could remove the flower pattern right off the dish! The underside is as clean as a whistle - no leaks or leak marks. The blower motor for the heating assy is stiff, so I will lube that. Nice Machine...
RCD |
Post# 420580 , Reply# 4   3/4/2010 at 22:56 (5,158 days old) by redcarpetdrew (Fairfield, CA)   |   | |
Post# 420583 , Reply# 5   3/4/2010 at 23:07 (5,158 days old) by 70series ( Connecticut.)   |   | |
Ooh. Nice Kitchenaid. One of my aunts had that exact one except hers was gold I think. Have a good one, James |
Post# 420587 , Reply# 6   3/4/2010 at 23:19 (5,158 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 420620 , Reply# 7   3/5/2010 at 06:29 (5,158 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
Post# 420701 , Reply# 8   3/5/2010 at 12:12 (5,158 days old) by pierreandreply4 (St-Bruno de montarville (province of quebec) canada)   |   | |
Post# 420717 , Reply# 9   3/5/2010 at 13:22 (5,158 days old) by whirlcool (Just North Of Houston, Texas)   |   | |
I always enjoy seeing your "pile finds". I find it just amazing that people would throw out such nice quality stuff just for minor repairs. |
Post# 420723 , Reply# 10   3/5/2010 at 13:38 (5,158 days old) by douglasdc6 ()   |   | |
So when was this one made ? I would like to know too!!!! |
Post# 420724 , Reply# 11   3/5/2010 at 13:38 (5,158 days old) by RevvinKevin (Tinseltown - Shakey Town - La-La Land)   |   | |
Post# 420732 , Reply# 12   3/5/2010 at 14:14 (5,158 days old) by rollermatic (cincinnati)   |   | |
i picked up one of those from a guy here in cinti last year for 50 bucks. he bought a new dishwasher and could not believe that it took over an hour and a half to do a load when his kdc-17 would do it in a half hour. he said if it weren't for his wife he would have kept the kdc. he was a restaurant manager and was big on hobart!
it might not have the bells and whistles like the superbas but it still is a great dishwasher! i put a new motor on mine even tho the old one worked fine. this was before i found any superba 17's and i thought the custom model might be all i would ever get. little did i know then that superbas were to start popping up all over the place! anyway, it looks great, better shape than the one i have, looks like it had an easy life which is good for you! enjoy it! |
Post# 420734 , Reply# 13   3/5/2010 at 14:17 (5,158 days old) by rollermatic (cincinnati)   |   | |
Post# 420735 , Reply# 14   3/5/2010 at 14:20 (5,158 days old) by aldspinboy (Philadelphia, Pa)   |   | |
Post# 420736 , Reply# 15   3/5/2010 at 14:21 (5,158 days old) by rollermatic (cincinnati)   |   | |
Post# 420780 , Reply# 16   3/5/2010 at 18:02 (5,157 days old) by douglasdc6 ()   |   | |
I have this model in coppertone in my kitchen , Although it came with the house & I`m afraid to use it it does display well. |
Post# 420804 , Reply# 17   3/5/2010 at 19:59 (5,157 days old) by appnut (TX)   |   | |
Post# 420880 , Reply# 18   3/6/2010 at 05:37 (5,157 days old) by douglasdc6 ()   |   | |
It hasnt ben in use since the 80`s I`m afraid something might short out . |
Post# 420906 , Reply# 19   3/6/2010 at 09:26 (5,157 days old) by redcarpetdrew (Fairfield, CA)   |   | |
Post# 420951 , Reply# 21   3/6/2010 at 13:59 (5,157 days old) by appnut (TX)   |   | |
Post# 420960 , Reply# 22   3/6/2010 at 14:24 (5,157 days old) by redcarpetdrew (Fairfield, CA)   |   | |
What I'd do first is pour a pot of hot water in the tub and check for leaks before running her. This will also help the seals after sitting for a while. If there are no leaks, run the drain to make sure it will drain and the drain lines to the sink are in good order. After all that, THEN you run a rinse cycle. If all that flies, Turn it loose!
RCD |
