Thread Number: 27438
Maytag 608 washer timer wire connections |
Post# 421269 , Reply# 1   3/7/2010 at 17:35 (5,162 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 421286 , Reply# 2   3/7/2010 at 18:44 (5,162 days old) by qsd-dan (West)   |   | |
Post# 422090 , Reply# 4   3/11/2010 at 21:39 (5,158 days old) by redcarpetdrew (Fairfield, CA)   |   | |
Post# 422093 , Reply# 5   3/11/2010 at 21:46 (5,158 days old) by redcarpetdrew (Fairfield, CA)   |   | |
Post# 422098 , Reply# 6   3/12/2010 at 00:00 (5,158 days old) by qsd-dan (West)   |   | |
First one is black from the regular/gentle push button switch which has two lugs going to the timer. One lug is mark "32" and goes to the back of the timer. To which terminal lug goes the second lug of this wire?
The 606 console I have sounds like it has a different timer manufacture than yours even though the part# is the same (Maytag sourced from both Kingston and Mallory for timers). On the 606 console, there is an unmarked terminal lug next to "32" which is where the second terminal goes. It's the only unmarked terminal lug on the entire timer, so look for an unmarked terminal lug that's about the same length as the wire. As for the timer wires, there are 2 lugs that are marked "TM". Since we are dealing with AC current, either wire can go to either terminal lug. Hope this helps! |
Post# 422103 , Reply# 7   3/12/2010 at 00:21 (5,158 days old) by qsd-dan (West)   |   | |
Upon closer examination, I take that statement back. There's a terminal marked "3S" (not 35) which is the terminal lug next to "32". The marking is considerably distant from the terminal, unlike all of the other terminals which are marked very close to their respective terminals. |
