Thread Number: 27547
Hotpoint "Compact Automatic Washer" |
Post# 422680   3/15/2010 at 09:50 (5,126 days old) by macboy91si (Frankfort, KY)   |   | |
So, thanks to Volvoguy, I went up to Columbus to pick up the little Hotpoint this weekend. The man selling the machine was very nice, and he said the machine hadn't been in regular use in about 20 years and that it did work, but it had no spin cycle. I was hopeful that maybe he just didn't realize that it didn't spin until the end of the cycle, but as it turned out, it didn't spin. The off-balance arm on the lid switch had became dislodged and not allowing the switch to close. Once that was out of the way and a lot of 409 spray, this little guy is a daily driver small enough to keep in the kitchen.
The machine was very clean inside and even the belt still looks new as I was also surprised that it was a belt drive at all. The electric pump works fine and the water level switch, lights and time all work. The inlet valve rattles, it may be going, but it still functions so for now I won't worry to much. This machine is very much like the modern Haier units aside from the extensive plastic. It has the same floating tub, and brake solenoid setup (you want to talk about loud!). The real difference is the extensive use of steel in this machine. Enamel outer tub and porcelain speckle inner tub. The cabinet is made of decent grade steel and all of the mounts are as well. The timer is also very neat, I love how it operates and sounds, and the overall control panel is very GE. The one odd thing about this machine is the lack of spins between rinses. It does 2 rinses, both are drain and fill only. I think the slightly newer version of this machine did spins between cycles but I'm puzzled as to why this version does not. Clothes come out nice and clean- and tangled. The water from the 2nd rinse runs clear so the whole no spin thing seems to work OK. Machine is fairly quiet, but not very powerful. When you watch the wash action with a "full" load it's a mild slosh, but it cleaned my work pants pretty well somehow. I'm posting my pics after the entry post because I can't create new posts with pics in them for some reason. -Tim |
Post# 422681 , Reply# 1   3/15/2010 at 09:55 (5,126 days old) by macboy91si (Frankfort, KY)   |   | |
The machine was filthy when I got it. It had some paint spilled on the control panel and the road muck from the drive home. The inside of the tub was pretty nasty too, lots of dirt and dust, the 1st water in it was pretty nasty. Here I took the control panel knobs off to clean the machine and repair the lid switch.
Post# 422683 , Reply# 2   3/15/2010 at 09:58 (5,126 days old) by macboy91si (Frankfort, KY)   |   | |
Post# 422684 , Reply# 3   3/15/2010 at 10:05 (5,126 days old) by macboy91si (Frankfort, KY)   |   | |
The off-balance arm had somehow managed to become dislodged. This bar works with the lid lever and both must be functioning. When the machine has an off-balance load and the tub rocks out and hit this it kicks the switch via a spring clip (near my thumb in the pic). Once tripped it required the lid to be opened and shut to reset. It "dangles" for lack of a better term and had slid out of it's slot. I thought about disabling the switch completely, but after running the machine with towels, I'm glad I kept it, it has a very "active" suspension.
Post# 422686 , Reply# 4   3/15/2010 at 10:09 (5,126 days old) by macboy91si (Frankfort, KY)   |   | |
I was surprised to see the under-lid instructions still in good shape. They are very clear, but there isn't much to remember here. This machine has a "Set Rinse Temp" light that comes on after the main fill of the wash cycle, it stays on through the rest of the cycle. While I like lights, it seems a lot of trouble for such an arbitrary thing.
Post# 422687 , Reply# 5   3/15/2010 at 10:13 (5,126 days old) by macboy91si (Frankfort, KY)   |   | |
Post# 422688 , Reply# 6   3/15/2010 at 10:22 (5,126 days old) by macboy91si (Frankfort, KY)   |   | |
For those who haven't seen one, it's a very elegant and simple setup. It reminds me of tuning in an old television in a way. There are no "cycles" only modes and times. Wash has a 12 min. max. range. The gap after "Wash" is the drain period. After that it fills and rinses (1st rinse) and the "*" denotes the 2nd rinse and then a drain and spin.
Post# 422708 , Reply# 7   3/15/2010 at 11:55 (5,126 days old) by macboy91si (Frankfort, KY)   |   | |
Since I'm at work I used Vimeo for this vid. Trying something different, but I will YouTube it later as well.
CLICK HERE TO GO TO macboy91si's LINK |
Post# 422877 , Reply# 9   3/16/2010 at 01:14 (5,126 days old) by StrongEnough78 (California)   |   | |
Post# 422882 , Reply# 10   3/16/2010 at 01:33 (5,126 days old) by RevvinKevin (Tinseltown - Shakey Town - La-La Land)   |   | |
Here is a longer video... yes it's the GE version, but it's the same thing! Kevin CLICK HERE TO GO TO RevvinKevin's LINK |
Post# 422884 , Reply# 11   3/16/2010 at 01:37 (5,126 days old) by StrongEnough78 (California)   |   | |
Post# 422904 , Reply# 12   3/16/2010 at 07:28 (5,126 days old) by macboy91si (Frankfort, KY)   |   | |
Give the people what they want!
I was pressed for time (sleep?) when I made this vid, I'll try and figure out how to film a complete cycle with the spin. This machine was on my dream list and I'm glad I found it. I think it's cool that it's the Hotpoint (rarer?) version even though there is no diffrence at all in the machine itself. Kevin, you want to have a GE portable wash-off, bring it! :) It's not a very powerful machine, but it seems to wash OK, water usage seems high for a little machine. 2 rinses is nice, but if it were to spin between wash and the rinses it would do much better. Does anyone know why it doesn't? I assume there's a reason. -Tim |
Post# 422912 , Reply# 13   3/16/2010 at 08:30 (5,125 days old) by RevvinKevin (Tinseltown - Shakey Town - La-La Land)   |   | |
Yes I agree. Personally my thought about this is.... this washer is portable, i.e, on wheels. Have you seen the way the washer moves around when it's at full spin and the tub brake comes on?? My thought is, if it had a spin after each wash or rinse as it should, the machine would be banging into the kitchen (or bathroom) cabinets every time it stopped the spin! Kevin |
Post# 422917 , Reply# 14   3/16/2010 at 09:25 (5,125 days old) by macboy91si (Frankfort, KY)   |   | |
I never really thought about it. It shakes the kitchen when it goes into spin if the load isn't perfect and that brake solenoid, it makes the cats jump. I would however settle for 1 rinse and a short spin with a coast-down and filling while the drum is coasting down. At the end of the final spin, if you listen to the motor, it starts winding down about 15-30 seconds before the brake kicks in. I don't know how it does that exactly but it could be used to ease the vibration and noise? It's irrelevant I suppose, since this design HAS been improved on and this IS a vintage little machine. Still neat though.
-Tim |
Post# 422930 , Reply# 15   3/16/2010 at 10:56 (5,125 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
The first rinse served as a cool down with the fast spin speed hot items would wrinkle it also helped prevent suds lock. The set rinse temp light was a very good idea with a portable washer if you were using a warm wash and left both hot & cold faucets open after the wash fill stopped the hot & cold water can mix in the plumbing system for the whole house or building this was often a real nuisance in an apartment building when the neighbors had hot water coming out the cold faucet and flushing toilets with hot water etc. Let alone taking a cold shower.
Post# 422932 , Reply# 16   3/16/2010 at 11:09 (5,125 days old) by RevvinKevin (Tinseltown - Shakey Town - La-La Land)   |   | |
Post# 422942 , Reply# 17   3/16/2010 at 12:03 (5,125 days old) by mistereric (New Jersey (Taylor Ham))   |   | |
Post# 422960 , Reply# 18   3/16/2010 at 13:28 (5,125 days old) by rll70sman (Hastings, Minnesota)   |   | |
Congratulations! And unique, to say the least! Hope it lasts for a while and that you get lots of entertainment out of it :-). |
Post# 422976 , Reply# 19   3/16/2010 at 14:12 (5,125 days old) by macboy91si (Frankfort, KY)   |   | |
I KNOW!!! I HATE this little camera that I've got. The Kitchen is very bright and I filmed the video on there with an ADDITIONAL desk lamp. It was a cheap USB video camera and I used it outdoors mostly, but indoors it literally drives me crazy. My other alternative is to use my old VHS-C camcorder and import the video with my capture card, but that is very cumbersome. This camera is one of the reasons that I haven't posted a lot of YouTube vids. I've got hours of footage of all of my machines, but they're not (to me) of good enough film quality to post.
Sidenote: I was referring to the extra timer wiring required to make that "Rinse Temp" light work. I think it's a great idea as well and neat. That would mean that the fill for the main wash would have to have it's own escapement that it can't share with any other fill? The timer looks really complex in this thing anyhow. -Tim |
Post# 423052 , Reply# 20   3/16/2010 at 19:16 (5,125 days old) by macboy91si (Frankfort, KY)   |   | |
Post# 423059 , Reply# 21   3/16/2010 at 19:37 (5,125 days old) by macboy91si (Frankfort, KY)   |   | |
Post# 423072 , Reply# 22   3/16/2010 at 21:19 (5,125 days old) by mickeyd (Hamburg NY)   |   | |
Sure I'd love to see it fill and spin.
Really nice video, Tim, and great story in your first post. Thoroughly enjoyed it. Welcome to the Washer in the Kitchen Club. Don't you just love it. Our friends across the pond all do it, but I think you and I are the only Americans doing it--Wait, Eric, too, I think. More later on no spin rinsing (I do it all the time); the Good Wife is on. YAY |
Post# 423182 , Reply# 23   3/17/2010 at 12:14 (5,124 days old) by mistereric (New Jersey (Taylor Ham))   |   | |
Much better! Sometimes when I am filming something I crank the hell out of the lighting, bring in extra lamps. I seem to do okay with my little canon elphs.
I am def. a member of washer-in-the-kitchen-anon, but only when I want to play with a portable. I was thinking of installing a box in the wall of the dining room, but maybe thats too much lunacy! |
Post# 423199 , Reply# 24   3/17/2010 at 13:39 (5,124 days old) by macboy91si (Frankfort, KY)   |   | |
Post# 423200 , Reply# 25   3/17/2010 at 13:40 (5,124 days old) by macboy91si (Frankfort, KY)   |   | |
Post# 423576 , Reply# 27   3/19/2010 at 11:42 (5,122 days old) by mickeyd (Hamburg NY)   |   | |
Sorry for the delay. I've been away. Thinks she's spinning at about 900 rpm's. That seems to be the standard for the portables, at least, that's how fast the WP/KM's go. I like the lighter touch of the Hotpoint's agitation; the Haier is a bit rough.
Tim & Eric: Once the washers come out of the closet--er, laundry room, there's no tellin' where they'll end up. I've been thinking the same thing about CPVC-piping a drain to the basement for the Lady K because the current long hose to the wet bar is a bit cumbersone when extended. Thanks again for the wonderful luncheon movie, and keeping me company with your conversation. One loves the "talkies" Your HP looks great in the kitchen. You'll be able to toss n' wash all your cooking and clean-up linens--and what does Frigilux call them, washmops? ;-D Just remembered during the Update & Preview: "barmops" ~ Eugene telepathy. Thanks again for the wonderful luncheon treat and keeping me company with your fine conversation. How I love the "talkies." |
Post# 423623 , Reply# 28   3/19/2010 at 17:07 (5,122 days old) by macboy91si (Frankfort, KY)   |   | |
I'm going to make some film of the Hoover 0510 across from it. I call her "Pearl", when I got her she hadn't been used since 1978! Anyway, you want to talk about the opposite of "weak impeller" wash, geez. It will throw some lighter things out of the tub if the water gets too low, I have marks on my wall to prove it :)
I'm going to use my VHS-C cam and hope for the best. I want a Flip cam, but at $179, Wal-Mart can keep them. I'm driving to Toledo in the morning to get a BEAUTIFUL coppertone Hoover 0512, SS tubs and never used I would beleive. I'm not going to use it probably but it'll be neat. I talk too much in my videos I think sometimes. -Tim |
Post# 423640 , Reply# 29   3/19/2010 at 18:12 (5,122 days old) by vacbear58 (Sutton In Ashfield, East Midlands, UK)   |   | |
Your videos are just great, and actually I think they dialogue adds a very friendly air to the whole thing. You have a great speaking voice too, although generally folks hate to hear the sound of their own voice. Look forward to vids or "Pearl" (do you know what age she is?) and also your new coppertone model
Al |
Post# 424380 , Reply# 30   3/23/2010 at 14:48 (5,118 days old) by macboy91si (Frankfort, KY)   |   | |
..is a White 1966-67 Hoover 0510 twin tub washer. The Coppertone model is a 0512 from 1970, it's one of the last SS tubs made and actually has the newer style spinner basket already. The quality on the coppertone 0512 is a tad shoddy in the SS seams and other smaller things, my guess is because of the change over to the poly-tubs, the last SS tubs QA suffered a bit.
Here's a pic of "pair". I think these were the only 2 colors offerered in the older styles. -Tim |
Post# 426828 , Reply# 32   4/4/2010 at 19:29 (5,106 days old) by bradross (New Westminster, BC., Canada)   |   | |
