Thread Number: 27562
1956 Cook AldWash |
Post# 422923   3/16/2010 at 10:15 (5,148 days old) by sudsman ()   |   | |
This was Cook Machinery First Automatic washer. the red formula dial was changeable to any formula wanted. This is a 35 lb machine. They had 50 and 75 and 100 # also. |
Post# 422943 , Reply# 1   3/16/2010 at 12:16 (5,148 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
Post# 423156 , Reply# 3   3/17/2010 at 08:28 (5,147 days old) by sudsman ()   |   | |
What you described sounds like MILNOR with a Miltrol like the one below but the Miltrol was on the left side at the top. and a lighted window let you see at a glance where the machine was in any cycle. |
Post# 423337 , Reply# 5   3/17/2010 at 23:24 (5,147 days old) by alr2903 (TN)   |   | |
Cook had a coin op machine similar to post 422923, they were usually built into the rear wall of the coin op, big metal door with a small square window. Suds you have the coolest pics, i like commercial machines. alr2903 |
Post# 423451 , Reply# 7   3/18/2010 at 18:37 (5,146 days old) by aldspinboy (Philadelphia, Pa)   |   | |
Lee when i was younger and hung out at this cool laundromat around the corner
they had one front load washer a 35 pound machine the window and handle was just like the one in the picture but no controls it was a coin op. The machine was a semi automatic in front of the washer was a long white plastic wash shelf that would extend all he way down to the extractor after the washer would wash drain, no spin, three HIGH level water rinses an i mean high... drain, tumble, STOP. Then unlatch open the door window wide, pull wet clothes out and slide them down to the extractor it was slightly tilted at one end so the water from the wet clothes would go into the spin basket... The spin basket had a mid shaft in the middle and slits for holes 35 cent more would spin the clothes very dry. The extractor was a ALDSPIN... Question for you do you think the system was all Aldwash & spin i would think they would be the pair. And that is how i got my name here, when they folded in the eighties the equipment was outside for a haul away think goodness i got the crest of the spinner. Ooh i see the work horse in that picture... that good old faithful DD washer there. Whirlpool or Kenmore ? Nice machines. Darren k. |
