Thread Number: 27645
Maytag Control Panel Swap |
Post# 423987   3/21/2010 at 15:46 (5,143 days old) by Pulsator (Saint Joseph, MI)   |   | |
Sooooo... I'm trying to put a center dial control panel on my recently acquired Maytag LA181. I'm pretty sure I did everything correctly however, when I plug the machine in, the breaker pops, even with the machine off. Any ideas? The only thing I can think of that would cause a problem is the fact that the LA181 does not have a suds saver. The control panel I'm using does. I have the wires that go to the suds saver taken off.
Post# 424002 , Reply# 1   3/21/2010 at 17:20 (5,143 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 424011 , Reply# 2   3/21/2010 at 18:08 (5,143 days old) by Pulsator (Saint Joseph, MI)   |   | |
Post# 424012 , Reply# 3   3/21/2010 at 18:25 (5,143 days old) by qsd-dan (West)   |   | |
Post# 424013 , Reply# 4   3/21/2010 at 18:32 (5,143 days old) by Pulsator (Saint Joseph, MI)   |   | |
There is a ground wire from the power cord to the cabinet, but no wire from the components of the control panel to the cabinet. There was a wire from the panel to the cabinet on the original LA181 control panel, but not this center dial panel.
On a good note, it will fill just fine, but will not agitate or spin. |
Post# 424027 , Reply# 6   3/21/2010 at 20:01 (5,143 days old) by qsd-dan (West)   |   | |
Post# 424038 , Reply# 7   3/21/2010 at 20:57 (5,143 days old) by Pulsator (Saint Joseph, MI)   |   | |
Nope, did the same thing! I even tried bypassing the lid switch as I plan on doing that anyway. It did something different when I bypassed the lid switch. Instead of popping the circuit once the the timer was pulled out and the lid was closed, it just popped the circuit even with the timer knob pushed in...
Post# 424061 , Reply# 8   3/21/2010 at 22:56 (5,143 days old) by lebron (Minnesota)   |   | |
